I don't know. Because it's so easy to change that setting, what they come with out of the box is irrelevant.Do most cameras come with ISO set to auto as a default setting?
These ISO invariant sensors I have been hearing about...are they primarily only full frame cameras?
YES!!! Changing the ISO value does not alter the light sensitivity of the sensor.You are correct in thinking that the sensitivity of the sensor does not change.
This needs to be a little clearer but what's critical here is that ISO is not a determinant exposure factor. Photographic exposure is the amount of light per unit area that reaches the sensor and is a function of the scene illumination, attenuated through the lens (aperture) over time (shutter speed). Three factors and ISO is not one of them. ISO informs the choice of exposure but does not otherwise alter the exposure. This is a huge point of contemporary confusion.Some photographers fiddle with the setting as if it were the third leg of an "exposure triangle", but in reality, changing the ISO has no effect whatsoever on the exposure.[emphasis mine]
the trouble with pedantry is that it turns into an infinite regress of "well no, actually"
for example, "well no, Ysarex, decreased exposure doesn't cause more noise, it causes a lower s/n ratio by reducing the numerator"
so what we actually do in practical terms is work with a simplified mental model that's good enough. rather than pedantically insisting that the sensor is the array of sensels, the bayer array, and the support circuits but not the amplifiers then we get to do the dramatic bit about how changing the ISO doesn't change the sensor's sensitivity, and then the noobs look on in confused wonder and then we can wander off into the weeds mixing up noise and signal-to-noise ratio, but nobody will notice because so so so very many words
if instead you include the amplifiers that implement ISO into what you mean by the word sensor, which is a perfectly reasonable thing to do (I am an ex-systems guy) then by god changing the ISO setting does indeed make your sensor (or "sensor system" if you prefer) into amore sensitive, albeit noisier, sensor (-system)
which is a perfectly good mental model to use, it works fine for millions of people successfully making billions of photographs every year.
tl;dr - yes, yes indeed, make ISO bigger makes them pichers brighter but noisier
well no it can record more data. suppose the sensor records volts, rounding down to the nearest volt, with an optional "amplify by 2x" circuit. this is simplified, of course.
consider a single sensel with a readout of 1.6 volts
without the amplifier, you read out a 1, which is off by 0.6 volts. with the amp you read a 3, which you interpret as 1.5 volts because you know about the amplifier for an error of 0.1 volts but most of this is irrelevant without considering the noise floor of the system which is determined in part by the support circuitry etc etc etc
see, you can play the "I know more fiddly details" game endlessly, but in the end it doesn't actually change the images you take one bit, it's just posturing. the fact that with some, but not all, modern sensors you can just shoot at ISO 100 and fix it in post is a mere curiosity.
"knowing" that changing the ISO "doesn't change the sensitivity" of the sensor has exactly zero practical impact on actually taking images
but i admit it sure makes you sound authoritative
so you exposed for the highlights at ISO 100 and, because your sensor system is ISO invariant, were able to recover the men.
if instead you had set the ISO to 1600 and then exposed for the men rather than the highlights you'd have blown out the highlights, ok.that is unsurprising. again: if you'd set the ISO up and metered in a completely different way you'd have lost the highlights.
if you have set the ISO to 1600 and exposed for the highlights, that is, exposed in the same way you did originally rather than metering completely differently, you'd still have to recover the men the same way, and they'd be all noisy.
but you could have used a faster shutter speed or a smaller aperture.
so.. let's see. setting the ISO to 1600 would have made the camera more sensitve, but noisier. right? did I get that right?
