Lens Trouble?
Discussion in 'Photography Beginners' Forum' started by bschneider5, Dec 21, 2008.
  1. bschneider5
    bschneider5 TPF Noob!
    Oct 30, 2008
    21
    I was taking pictures last night, everything was OK until I switched to my Nikon DX AF-S 55-200 1:4-5.6G ED lens. I found that the autofocus will not work. I took it off, put it back on and tried it on my neice's camera (D40) and it will not work on her camera either.
    I'm a bit of a beginner so I don't think I have settings wrong. Especially since my 18-55mm lens works fine. I haven't dropped the lens or anything. Any ideas on what the problem might be?
  2. TwoRails
    TwoRails TPF Noob!
    Nov 9, 2008
    1,149
    The Great Northwest
    Sounds like it could be a lens problem. Do other lenses work OK on those cameras?
  3. bschneider5
    Oct 30, 2008
    21
    Yes, other lenses work with the camera. Nothing seems to be rattling around or anything. I guess I need to see about getting it repaired. I have only had it for about 6 months, I suppose there is a warranty for this?
  4. Early
    Early TPF Noob!
    Feb 8, 2008
    1,240
    Western NJ
    It should, but before you pack it up, try cleaning the contacts on the rear of the lens with a pencil eraser.
  5. AlexColeman
    AlexColeman TPF Noob!
    Dec 13, 2008
    1,732
    Try this, and also check the switch, it might be stuck, flip it back and forth a few times.
  6. bschneider5
    Oct 30, 2008
    21
    I did the eraser trick, no difference. Also exercised the switch. I never noticed it before, but when rotating the barrel, there seems to be an increase in resistance as I zoom in further. Is this normal?
  7. TwoRails
    TwoRails TPF Noob!
    Nov 9, 2008
    1,149
    The Great Northwest
    Should be a warranty, but it depends on if you bought it new, used, grey market, etc... I just looked at B&H and they list a 5 year warranty for that lens.
  8. bschneider5
    Oct 30, 2008
    21
    Thanks guys for the input. I boxed it up, will be sent to the repair facility tomorrow.
  9. TwoRails
    TwoRails TPF Noob!
    Nov 9, 2008
    1,149
    The Great Northwest
    I assume you mean return it for warranty repairs?
  10. bschneider5
    Oct 30, 2008
    21
    Yes, I spoke with a lady on the phone from Nikon, she said I needed to send it in with my papers and they would evaluate it. She said unless is was dropped or water damage or something that would void the warranty they would repair it. If it isn't covered, I would have the option of having them fix it or send it back to me.
    At that point, I'm not sure what I would do for repair. I would imagine they are pricey, as would any repair facility be?
    BTW, I purchased it new in June from Costco.com as part of a bundle with my D40.
  11. TwoRails
    TwoRails TPF Noob!
    Nov 9, 2008
    1,149
    The Great Northwest
    Sounds good. Hope it works out well for you.
