Looking for a wider lens?
Discussion in 'Photography Beginners' Forum' started by chrisburke, Sep 10, 2008.
  1. chrisburke
    chrisburke TPF Noob!
    May 25, 2007
    2,107
    Madoc, Ontario Canada
    pardon my terminology here but i'm looking for a wider lens... all I have is the kit lens and the 70-300mm I'm looking for something that is wider.. if that makes sense.. for example.. the lens in the following picture was a nice wide lens.. I dont know what it was, it wasnt my camera, I was using a friends...
    [​IMG]
    I use nikon and i'm just looking for something wider.. does this make sense at all??
  2. Dubious Drewski
    Dubious Drewski TPF Noob!
    Jan 18, 2008
    909
    4
    Lethbridge, Alberta, Canada
  3. prodigy2k7
    prodigy2k7 No longer a newbie, moving up!
    Apr 22, 2008
    1,667
    22
    California, USA
    Looks like a Canon EF 16-35mm f/2.8L II USM
    Hard to tell, cant see the ring, but it looks the same in body construction
  4. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    That lens looks like the 17-85mm IS.
    You want a lens that looks wider...as in physically bigger? Or do you want a wider field of view (shorter focal length)?
    What is your kit lens...18-55mm?
  5. Overread
    May 1, 2008
    24,079
    4,175
    UK - England
    Darn I knew that kids were starting earlier with more expensive kit that that is just ----
    As for wider lenses the sigma 10-20mm is a very good (and cheaper than the top nikon/canon brand) wideangle lens for crop sensor cameras
  6. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    I can vouch the the Nikkor 12-24mm f/4 is a wonderful lens, but if budget minded, I have seen enough images from the Sigma 10-20mm that it is a bang for your buck.
  7. andrew99
    andrew99 TPF Noob!
    Jan 23, 2008
    672
    Toronto, Canada
    I have the Sigma 10-20 for Nikon, and I'd definitely recommend it!
  8. Montana
    Montana TPF Noob!
    May 27, 2008
    1,533
    Eastern Montana
    If you don't know the terminology of what a wide lens is, I would suggest not blowing a whole paycheck on one. Get a sigma or something cheap.
    Derrick
  9. dhilberg
    dhilberg TPF Noob!
    Jul 26, 2008
    516
    Washougal, WA
    I've heard the Tokina 11-16mm f/2.8 is also very good, and it's fairly inexpensive, about $570 USD. It won't autofocus on your D40 though (it will on your D50 I think), you'll need the Nikkor 12-24mm f/4 for that.[FONT=Helvetica, Arial, sans-serif][/FONT]
  10. Dubious Drewski
    Jan 18, 2008
    909
    4
    Hey, you guys use the 10-20 also? Sweet, I thought I was the only one.
  11. prodigy2k7
    Apr 22, 2008
    1,667
    22
    California, USA
    EF-S 17-85MM f4-5.6 IS USM, its not this, the the focus ring is behind the MF switch on the picture... The 17-85 has the focusing ring infront of the switch
  12. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    Does it really matter in this case? :confused:
