Natural light question
Discussion in 'Photography Beginners' Forum' started by prsheba, Apr 25, 2007.
  1. prsheba
    prsheba TPF Noob!
    Apr 25, 2007
    5
    Chicago
    I'm a newbie and tried to find an answer via searching the forums but unsuccessfully.
    I was at a friend's birthday party. She was opening gifts in front of the patio but inside. However there was a lot of natural light filling the room. But my pictures look a bit hazy and the outer edges were bright white - no color definition.
    I shoot with a Nikon D50 - WB was direct sunlight - 50mm/1.8 lens Nikkor AF
    Should I have used a flash? I'm sorry I don't have a picture to post (I'm at work..shhhh)
  2. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    hard to tell, maybe you had a wider range of brightness than you camera can handle? maybe some parts of the images are jts badly overexposed?
    wohaa.. 500mm on an aps-c sized sensor appears very long for this sort of photography.
  3. darich
    darich No longer a newbie, moving up!
    Jan 22, 2005
    1,230
    Near Lanark, Scotland
    i don't think it would be direct sunlight - probably more like cloudy.
    Probably a better bet to leave it at Auto
    And 500mm???...that's a HUGE room!!!
    I guess you meant 50mm!!!
  4. prsheba
    prsheba TPF Noob!
    Apr 25, 2007
    5
    Chicago
    oops I meant to say 50mm/1.8
  5. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    my brain started already wondering how come you have a f/1.8 that long :p
    fill flash might help with your problem. but i am not sure i really understand the shooting situation and the outcome.
  6. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    Seeing pictures would help in this ALOT
  7. xfloggingkylex
    xfloggingkylex TPF Noob!
    May 5, 2006
    1,292
    Frederick, MD
    Any filters on your lens? Also did you happen to be in the sunlight? The haze would seem to be from light on the front of your lens, Im guessing you didn't have a hood?
    When you get home, post a picture and this problem will get solved much sooner.
  8. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    My guess is that your subjects were backlit and you probably have some flaring.
  9. prsheba
    prsheba TPF Noob!
    Apr 25, 2007
    5
    Chicago
    ok..finally home..here is the picture..any ideas what I did wrong?
    [​IMG]
    shooting data...
    Focal Length: 50mm
    Exposure Mode: Programmed Auto
    Metering Mode: Multi-Pattern
    1/25 sec - F/2.5
    Exposure Comp.: -0.3 EV
    Sensitivity: ISO 200
    White Balance: Direct sunlight
    AF Mode: AF-A
  10. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    That's lens flare and blown out highlights.
  11. prsheba
    prsheba TPF Noob!
    Apr 25, 2007
    5
    Chicago
    aw mann. this just sucks. Well at least I know what the problem is now. Thanks!
