Nikon D7000 ERR messages!
Discussion in 'Nikon Cameras' started by atp2008, Feb 25, 2012.
  1. atp2008
    atp2008 TPF Noob!
    Feb 25, 2012
    I have 2 Nikon D7000 bodies and one is only a few months old, but last week, it stopped taking photos and only displays a "ERR" error message when I press the shutter. It looks dim when I look in the viewfinder and won't capture any images. I hear the mirror flipping, but that's it. I've sent this camera back to Nikon to get fixed, but in the meantime need to shoot with one camera only. (I am a family photographer.)
    Has anyone gotten this ERR message with their D7000? When I google this problem, it sounds widespread, which worries me. I am wondering if I should sell my D7000s and get something else if this is some kind of defect.
    Would love your input, especially of you own a D7000!
  2. 480sparky
    480sparky Chief Free Electron Relocator Supporting Member
    Mar 8, 2011
    21,637
    7,719
    Iowa
    Page 306 of your manual.
  3. rgregory1965
    rgregory1965 No longer a newbie, moving up!
    Aug 15, 2011
    711
    84
    arizona
    Re-Seat yout SD cards
  4. LizardKing
    LizardKing No longer a newbie, moving up!
    Aug 31, 2011
    757
    87
    Buenos Aires, Argentina
    Hello!
    Seeing the OP's question has already been answered, I'd like to ask you about another error I get once in a while on my D7000... It's just this "- E -" that appears on the control panel (small screen on the top of the camera.
    I'm sure it has something to do with the memory cards, because it appears in the same place where it normally says how many more shots are left... But couldn't find anything in the manual.
    It doesn't matter if I turn off the camera, the "- E -" stays there until I re-place the memory cards... but I'm kind of worried about removing the cards while that message's still there...
    Thanks in advance and have a nice day!
    EDIT: Nevermind... the answer was on page 307... Can't believe I couldn't find it before... Anyway, it means the camera cannot detect a memory card. Now, the question is what could be causing this?
    Regards,
    LizardKing
  5. 480sparky
    Mar 8, 2011
    21,637
    7,719
    Iowa
    You either have no memory cards inserted, or they are on the Write Lock position.
  6. Netskimmer
    Netskimmer No longer a newbie, moving up!
    Jul 23, 2009
    1,392
    229
    North Carolina
    The card could also be bad.
  7. Rhodes454
    Rhodes454 TPF Noob!
    Jan 1, 2012
    14
    I had the same thing. I was using a Kingston 16GB for raw and an 8GB for JPEG and the D7000 just did not get on well with the 8GB card (gave the error message about once every 50 shots or so. Once the card was removed and replaced, everything would be fine for a while). Eventually, I got fed up and replaced the cards with SanDisk versions and have not had any trouble. I think this kind of thing is more likely to be card-based rather than camera-based. The OP's problem sounds a little different though. If the viewfinder looks dim, I'd say that there is maybe something triggering the DOF preview.
  8. atp2008
    atp2008 TPF Noob!
    Feb 25, 2012
    I tried everything and eventually sent my D7000 to the Nikon Service Center. They said they needed to replace a part!
    As for a replyer's issue with getting the -E- message, I get that from time to time too. It's usually from accidentally pushing the "lock" switch in my SD card when I inserted it into the camera, so your camera reads that as no cards available (even though one or two are inside). You may want to check that first. If it's not locked, then it probably is the card itself, like someone already mentioned.
    Thanks, everyone, for commenting!
  9. Snoggin
    Snoggin TPF Noob!
    Jan 22, 2012
    33
    Marin county
    I had some sandisk 16 gb cards and kept getting the error message also. On e ingot a different message that said my card was.corrupted. Since both were within the return period I returned both and got another pair. No problems since
  10. jriepe
    jriepe TPF Noob!
    Dec 21, 2011
    500
    38
    Chicago area
    Today June 10, 2012 I was out with my Nikon D7000 when it stopped working. I am getting the blinking Err message. Page 306 of the manual says, "Release shutter. If error persists or appears frequently, consult Nikon-authorized service representative." I can access the menu to make changes and I can view the images that were taken but many other features are non functional. The flash unit will not raise, The ISO button as well as the metering button are non functional. Live view does not work and probably many other things I haven't even tried. I am convinced this is a REAL problem and not something as simple as cleaning the lens contacts, using a fully charged battery, reseating the SD cards, etc. In researching this I found this to be a rather common problem with this particular model. I watched a You Tube video of a D7000 acting the same way as mine. Fortunately there is a Nikon authorized repair service not far from where I live so it will be heading for the shop tomorrow morning. If you have a D7000 be aware that the problem I'm experiencing does not appear to be an isolated case by any means. I will follow up and let all know the outcome.
    Jerry
  11. jriepe
    jriepe TPF Noob!
    Dec 21, 2011
    500
    38
    Chicago area
    UPDATE: Today June 11, 2012 took my D7000 to United Camera where a tech. took a quick look and informed me the camera has a bent shutter blade. Total cost including tax for the repair is $147.86 PROVIDED the sensor did not get scratched from the bent blade. The camera is not under warranty and I was told that even if it were Nikon would need to determine if this was a manufacturing defect or operator error caused by possibly a sensor cleaning. The sensor has never been cleaned by me nor anyone else. Right now I can only hope the sensor has not been scratched.
    Jerry
  12. xjoewhitex
    xjoewhitex TPF Noob!
    Jan 8, 2011
    419
    14
    Ohio
    You know things can and will go wrong I wouldn't think this is some widespread problem, as Ive never heard about it. Im curious tho, how much use has your camera seen?
d7000 err
d7000 err message
d7000 error message
err nikon d7000
nikon d7000 err
nikon d7000 err message
nikon d7000 error
nikon d7000 error codes
nikon d7000 error message
nikon d7000 error messages
