Pentax K1000 Battery Cover Stuck!
Discussion in 'Photography Equipment & Products' started by tempra, Mar 2, 2007.
  1. tempra
    tempra TPF Noob!
    Feb 26, 2005
    1,669
    9
    Oxford, UK
    Picked up a coule of K1000's the other day, one had a stuck shutter - that was easy enough to sort out, but one of them has the screw cap for the battery compartment seized shut.
    I've tried brute force and ignorance, with a coin, large screwdriver, a couple of darts and some pliers, but it isn't going to budge.
    The battery had leaked inside, I have the baseplate off, and the bad battery out but I cannot for the life of me get the screwplug out - anyone any ideas as to how I could loosen it? tried tapping it with a rolling pin but it started to bend and still no joy.
  2. perylousdemon
    perylousdemon TPF owns my soul...
    Jan 29, 2007
    299
    Pittsburgh, PA
    Hmm. Quite a predicament. All the battery operates is the light meter; if you don't need the light meter, then it doesn't seem worth the trouble to get the compartment open. Besides, the compartment would need cleaned extensively if the previous battery leaked while it was inside.
  3. Jeremy Z
    Jeremy Z No longer a newbie, moving up!
    Jan 4, 2007
    1,171
    31
    Chicago burbs
    A trick people use to clean battery corrosion is vinegar. You might try swabbing some vinegar in there on a drenched Q-Tip. Let it soak for a while, and try it again with a large coin. (one that is thick enough so that you won't strip the slot)
    If that doesn't work, a drop of oil in the threads might be OK, if you clean it out afterwards. Just a tiny drop, mind you.
  4. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    345
    North New Jersey, United States of America
    Remove the bottom plate and find another on ebay... pretty cheap to find.
    Had something similar happen to me on a spotmatic... removed it with a little heat (after removing the bottom plate).
  5. Johnboy2978
    Johnboy2978 No longer a newbie, moving up!
    Oct 21, 2004
    1,797
    30
    Southwest Virginia
    WD40?
  6. tempra
    tempra TPF Noob!
    Feb 26, 2005
    1,669
    9
    Oxford, UK
    Cheers guys, I'll give the vinegar a go, failing that WD40 and then heat.
    Can't find any bottom plates listed on ebay - google found one but it was a completed listing :(
  7. usayit
    Nov 15, 2003
    9,523
    345
    Try "K1000 parts" in your search on ebay instead.... I picked up one for 10 bucks once to replace a seized battery cover and a bent shutter handle.
    Either case, it is pretty easy to remove the bottom plate. Whatever you try, WD40, vinegar, or heat, I recommend removing the bottom plate to protect the rest of the camera.
  8. lostprophet
    lostprophet No longer a newbie, moving up!
    Feb 10, 2006
    11,770
    109
    we've been known to use boiling water to loosen the odd battery cap, the heat expands the baseplate ( which is OFF the camera ) and loosens the cap
battery cap stuck on 35mm camera
battery cover for pentax k 1000 35 mm camera
changing battery k1000 stuck
how to remove a battery from a pentax camera
pentax battery stuck
pentax honeywell stuck battery cover
pentax k1000 battery
pentax k1000 battery cover
pentax k1000 battery cover stuck
pentax spotmatic battery cover stuck
