Question about monitor calibration.
Discussion in 'Beyond the Basics' started by eclipse13, Mar 2, 2008.
  1. eclipse13
    eclipse13 TPF Noob!
    Feb 19, 2008
    88
    Wilmington/Greenville, NC
    I borrowed a monitor calibrator from a friend and got mine looking right. But as soon as I unplug the calibrator or turn off the program, it resets to the way it used to look. Is there any way to make my monitor keep the same setting and look after I unplug the calibrator?
  2. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,965
    14
    Durham, UK
    Save the calibrated profile as your default in the graphics card software. H
  3. Samurai Photographer
    Samurai Photographer TPF Noob!
    Jan 3, 2008
    23
  4. eclipse13
    eclipse13 TPF Noob!
    Feb 19, 2008
    88
    How do I do this? I am pretty familiar with computers but I can't figure out how to do that.
  5. Flash Harry
    Jun 26, 2006
    1,965
    14
    Durham, UK
    Your'e calibration software should lead you step by step to creating a profile you can save, save it as something you'll recognize, then set this as default in your display properties. I cant really help further as I'm not familiar with the system and dont have my crystal ball handy. H
  6. eclipse13
    eclipse13 TPF Noob!
    Feb 19, 2008
    88
    I am using the Pantone Huey, the one that samurai posted. It doesn't seem to make a change unless the program is running in the system tray, but I'll see if I can figure something out. Thanks for the help.
  7. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    I'm considering purchasing the Spyder monitor calibrator, they are available from amazon for under $100... but I have a few other things I want to get before that. ;)
  8. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    Hell's Kitchen, New York
    What OS are you using, and do you have Photoshop?
    If you are using Windows is there anything in your startup folder that might be a profile loader? Do you have Adobe Gamma in your Control Panel?
    Best,
    Helen
  9. eclipse13
    eclipse13 TPF Noob!
    Feb 19, 2008
    88
    I'm using windows xp and have PS CS2. Adobe Gamma is in my control panel.
  10. Helen B
    Helen B TPF Noob!
    Sep 16, 2007
    3,296
    465
    When you used the calibrator, did the software save an .icm file? It should have done. That's what the profile loader should be using. The profile loader shortcut should be in somewhere like
    C:\Documents and Settings\All Users\Start Menu\Programs\Startup
    You should be able to see it in the Startup tab if you Start>Run>msconfig
    If the calibration software hasn't installed a profile loader, you can use Adobe Gamma:
    Make sure that it is selected in the msconfig Startup tab, that should make a shortcut appear in C:\Documents and Settings\All Users\Start Menu\Programs\Startup
    Then open Adobe Gamma from the Control Panel, and hit the Load button. Then select the .icm profile the calibration software made.
    Restart Windows.
    Remember that when the calibrator is working, any monitor profile that was active needs to be disabled, otherwise the calibrator isn't making a profile for the monitor, but for the profiled monitor. Disabling the profile will make the screen look different.
    Best,
    Helen
  11. snra786
    snra786 TPF Noob!
    Feb 20, 2007
    24
    I'm not too familiar with calibrators but don't they change the monitor settings depending on the ambient light around the monitor? Probably should invest in one for yourself.
  12. chinpokojed
    chinpokojed TPF Noob!
    Mar 6, 2008
    102
    Atlanta
    Absolutely -- plus all ambient light will change over time, and so will the color the monitor reproduces.
    I work in Fine Art Reproduction where color is absolutely critical and we re-calibrate our monitors about every 14 days.
    We use this one for monitor calibration, but really all of them work fairly well.
    http://www.amazon.com/Pantone-MEU103-Eye-One-Display-2/dp/B000CR78CO
