Raw Photos Camera Recommendations
Discussion in 'Photography Equipment & Products' started by Kal152, May 23, 2016.
  1. Kal152
    Kal152 TPF Noob!
    May 23, 2016
    4
    Hi,
    I am looking for some advice or recommendations on cameras. I am not a professional photographer, I am an Interior Designer and would like to take pictures of my own work, a professional is not needed for every job. I have minimal experience with photography but have experience with Photoshop to adjust the quality of my pictures. I would like to purchase a camera with Raw shooting capabilities for better editing. I do not want to spend alot of money or have anything to elaborate. Can anyone make and recommendations?
  2. robbins.photo
    robbins.photo Yup, It's The Zoo Guy Supporting Member
    Oct 3, 2013
    11,518
    4,785
    Louisville, Nebraksa - United States
    Ok, so what is "not a lot of money" to you? Also, are you only wanting to purchase something new or is used possibly an option?
  3. Kal152
    Kal152 TPF Noob!
    May 23, 2016
    4
    I was looking at new but used isn't out of the question. I wanted to try to stay under $300
  4. robbins.photo
    Oct 3, 2013
    11,518
    4,785
    In that case I'd probably look around for a used D3200 with a kit lens. It will have a larger sensor than a smaller, compact camera so you'll be able to get much better shots in lower lighting situations which you'll encounter a lot indoors. It's high dynamic range will also come in very handy for these situations. It will shoot in RAW, controls are pretty simple and straightforward, and if needed you can add an external flash unit for those times when you need a bit more light.
  5. Kal152
    Kal152 TPF Noob!
    May 23, 2016
    4
    Thanks! I will look into that one more
  6. robbins.photo
    Oct 3, 2013
    11,518
    4,785
    I shot a D5200 for quite a while, image quality is first rate. At some point depending on how small the rooms are your working with maybe a wider angle lens might be in order, but with a bit of forethought you should be able to get most of the shots you need with the kit lens and maybe an external flash or some additional lighting.
    That will probably be the biggest struggle for most cameras, interior lighting works fine for the human eye but cameras tend to need a bit more light to get a proper exposure.
  7. KmH
    Apr 9, 2009
    40,738
    5,588
    Iowa
  8. goodguy
    goodguy Been spending a lot of time on here!
    Dec 5, 2012
    5,545
    1,113
    Toronto Canada
    300$ ?
    Try to look for a used Nikon D3200 or used D3300
  9. Kal152
    Kal152 TPF Noob!
    May 23, 2016
    4
    Guess I should have explained more I will not be adding any additional lighting. I just want to take some basic pictures and enhance the lighting on photoshop. After I do the basic photos I will determine if I need for any reason to hire a professional. I do alot of Kitchen and Bath projects and they don't all photograph well due to size and layout.
  10. Designer
    Designer Been spending a lot of time on here!
    Apr 13, 2012
    16,384
    4,107
    Iowa
    I'm curious about how that would look. I have never attempted adding light via Photoshop, and I would like to see an example of one that you did, if you would be so kind.
  11. PaulWog
    PaulWog No longer a newbie, moving up!
    Jun 17, 2013
    1,153
    188
    Canada
    You will need an ultrawide lens alongside the camera. The big concern will be distortion.
    A good professional photographer would likely have a full frame camera with a good ultrawide lens. The reason why a cheap ultrawide lens (might) not do too well is because of weird distortion; mustache distortion, or other distortion patterns, can make straight lines look wonky. Such distortion is not always correctable. It is much simpler (automatic in photoshop or lightroom) to correct for barrel or pincushion distortion, although you may lose some of the width of your shot by correcting for such distortion.
    Lighting will be absolutely essential. Photography is all about lighting. You can boost shadows in lightroom or photoshop after the fact, but you will lose detail, significantly degrade color, and introduce lots of noise (if you're relying on only that and not bringing any lighting with you physically to the shoot). With a full frame camera this is a bit easier to get away with, since you can boost your ISO a bit, and recover shadows a little more easily, but lighting is still important.
    Photoshop can't change the lighting in your shot. You can boost exposure, fake some lighting (within limits), and make adjustments, but that only takes you so far.
  12. beagle100
    beagle100 No longer a newbie, moving up!
    Mar 31, 2015
    1,813
    444
    look at refurbished - Canon 600D, 650D, etc. but I agree with the other poster, lighting is essential for good product photography
