understanding hue and saturation
Discussion in 'Photography Beginners' Forum' started by Dylan, Sep 27, 2006.
  1. Dylan
    Dylan TPF Noob!
    Aug 30, 2006
    226
    Delaware
    I shoot a lot of flowers and I want to understand hue and saturation so I can give them some punch. Can anyone point me to a primer on the subject? I've played around with this in Photoshop but I really want to understand what I'm doing instead of just winging it.
  2. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
  3. KevinR
    KevinR TPF Noob!
    Feb 1, 2005
    1,204
    4
    Dearborn, MI
    Google that and also Lightness/Contrast is also your friend for getting punch.
  4. rmh159
    rmh159 TPF Noob!
    Jun 13, 2006
    1,028
    Milwaukee, WI
    Levels and curves are what I use for contrast, color correction. I've always felt that when I start changing the hue in pictures that it looks fake unless you're sampling colors from another similarly lit pic.
  5. Dylan
    Dylan TPF Noob!
    Aug 30, 2006
    226
    Delaware
    I use levels and curves as well but I don't feel that I know what I'm doing. Thanks for the link Rob. Google it .... why didn't I think about that. DUH
  6. LaFoto
    Feb 1, 2004
    34,813
    817
    Lower Saxony, Germany
    While I started out using the curves in PS for some contrast corrections I have turned to the levels now, liking them more because they give you the histogramme of the picture. So you can see at once whether your pic lacks in highlights or dark element, of if you've got a considerable lack of midtones. So you can add some of either or push the middle button so you increase some of the midtones ... and you see what you are doing right away. Sometimes it is only a matter of tiniest adjustments to make the colours pop out more. I hardly ever even touch the "Saturation" level any more.
  7. rmh159
    rmh159 TPF Noob!
    Jun 13, 2006
    1,028
    Milwaukee, WI
    Levels is fairly easy to explain.
    The histrogram shows where the light is distributed in the pic. The far left of the graph is pure black and the far right is pure white. Most pics won't have an even distribution of points on that curve and it'll be skewed one way or the other. Regardless... if your pic doesn't have a lot of data (the graph is low with data close to they Y axis) it's telling you that the pic doesn't have much that's white / black. When you move those sliders in you're telling it that what points it considered near white... you want it to now consider pure white. When you do that with both the black and white sliders you'll get a better tonal range and more contrast.
    You can then use the grey slider to adjust midtones but I've found those adjments are usually more subtle than the black and white.
    You should notice a significant difference with this.
    Curves is a bit more detailed. This should answer your questions though. http://www.cambridgeincolour.com/tutorials/photoshop-curves.htm
understanding saturation in photography
