vibrance challenge!
Discussion in 'Photoshop Challenges' started by magicmonkey, Feb 24, 2006.
  1. magicmonkey
    magicmonkey TPF Noob!
    Feb 11, 2006
    579
    Bristol, UK
    Here's a photoshop challenge for you, I took this picture becasue the colours were really vibrant and as my name's Ben I thought it might make a good avatar or something, the problem is that it looks quite washed out and I really can't work out how to get it looking as vivid as it did in RL without setting the saturation up so high that it ruins the photo!
    [​IMG]
    Any help would really be appreciated!
    *EDIT* I think I should also get the award for longest ever sentence! *EDIT*
  2. LaFoto
    Feb 1, 2004
    34,813
    817
    Lower Saxony, Germany
    Something like this then? Or have I overdone things now?
    [​IMG]
    Oops. That has become small..........:(
  3. magicmonkey
    Feb 11, 2006
    579
    Bristol, UK
    Almost something like that yeah, it looks like it's a bit over saturated though and I'm after a really 'natural' feel to the shot. It might just appear over saturated because it's been shrunk as well though!
  4. magicmonkey
    Feb 11, 2006
    579
    Bristol, UK
    I've just had a play about with it and I think it was because it was small that it looked over saturated! So what changes did you make to it?
    ps. Thanks as well!!! :p
  5. LaFoto
    Feb 1, 2004
    34,813
    817
    I shifted the curves a little, just so you get a vibrant "Ben" but don't lose too much of the wood in the lefthand bottom corner, and added a +10 of saturation.
  6. magicmonkey
    Feb 11, 2006
    579
    Bristol, UK
    wonderfluff, thanks LaFoto, I'll have a go at that when I get home! Well, maybe tomorrow morning, it is Friday after all :)
  7. woodsac
    woodsac TPF Noob!
    Jul 14, 2005
    5,712
    260
    In a black hole
    Here's another attempt. Not sure that it's any different than LaFoto's?
    [​IMG]
  8. LaFoto
    Feb 1, 2004
    34,813
    817
    Well, it definitely is bigger!
    And I guess you saved the wood even better.
    You work differently with PS --- I am sure you use things that I hear mentioned all the time and know nothing about, such as channel mixers and all such things --- or even different layers?
    I still haven't found out how all this layer-"business" works...
  9. magicmonkey
    Feb 11, 2006
    579
    Bristol, UK
    Thanks Woodsac! Could you tell me what you did to it as well?
  10. woodsac
    woodsac TPF Noob!
    Jul 14, 2005
    5,712
    260
    In a black hole
    Saturation was adjusted by individual colors. Tiny levels adjustment, brightness/contrast and some shadow/hilight tweaks.
    All pretty basic adjustments. I think what helped the most was the shadow/hilight. By lightening the shadows you bring out more detail. Then I could up the contrast a little to darken up the colors. That way you don't have to try and make your colors pop with saturation.
  11. magicmonkey
    Feb 11, 2006
    579
    Bristol, UK
    Thanks for all the help guys :) I've had a play around and you can see the results at the top. I couldn't find where to play around with the shadows/highlights though, could you point me in the right direction?
  12. woodsac
    woodsac TPF Noob!
    Jul 14, 2005
    5,712
    260
    In a black hole
    I'm using PS CS2.
    Go to >Image >Adjustments >Shadow/Highlights
