What is my Nikon 85mm 1.8 doing???
bdavis
Iowa
I took this picture and the bokeh sucks! Is this a problem with the lens??
Really?
Cause I'm hardly doing any post processing to it and that's what I get.
When I bring my camera's shots into photoshop through photoshop camera raw, they always look desaturated, so I just boost it a tiny bit, that's it.
No, but for some reason when I bump the saturation up even just a little (like +10) it does this. I'm not sure why. The color comes out a little flat when I import the raw files via photoshop camera raw so I have to do the saturation adjustment.
I use camera raw to import and then do the editing in photoshop. It's how I've always done my editing and this has never happened. Only when I started using the lens did i see this.
Ahh bumping saturation. Are you processing in 16bit? Are you processing JPEGs? What do you do before the saturation? Is the saturation on a separate layer? If so how is the blending done?
A quick look seems to indicate that only certain brightness bands are being saturated. Assuming you're working in 16bit colour I would blame any layer blending options, or masks on that effect.
I opened your image and see that you have no color space assigned to it, When I looked at the Saturation levels, the image is over saturated, and your shadows also are suffering clipping.
I find it odd that your version of CS4 for Windows has not been set to apply an image color profile tag to the image. It seems to me that what you are seeing is largely within your own Windows system and the way your computer is displaying the image.
Your screen capture of the yellows does not look at ALL like what I see. What color space are you working in? What color space do you want to assign to images to be shown on the web?
