Dave_D
Okay there scientist. You have light leaks!! I have had them, have seen them, have seen others have them, fixed my own camera to stop them and fixed other peoples cameras to stop them. You have light leaks. Maybe your seals are worn. Maybe the latch doesn't hold your door closed as tight as it once did, but you definitely have light leaks. One person I know only had leaks when shooting vertical. Nothing wrong with the camera at all. How tight he squeezed the camera when holding it vertical was his problem.
Your first image has blue on the right but not a light leak. That is lens flare. The other side of the image has a light leak which is also apparent on the other two of your images and in the same area on all. They are light leaks! Here's a link to see some light leaks on video footage that is pretty cool:
http://www.fotosearch.com/video-footage/light-leaks.html
You actually have some pretty good samples of what a light leak looks like. You are well equiped to show the next person who asks what a light leak looks like
BTW, Alot of black and white is C41 process (color).
