10 Pounds Down
Kazooie
Alaska
*snip snip*
Nope, just having fun and showing off my tummy! :)
110 is pretty slim. How tall are you that you want to weigh 110? My roommate is 5'5 and his ideal weight is still around 120lbs.
20 more pounds and we'll call you Skeletor. :) I personally don't think skinny is attractive at all. At least start working on some definition. But great job on the 10lb loss and the continuation of your goals.
I don't weigh myself in pounds, but from what I can see here, 20 less of those would mean "skinny", and that is simply NOT GOOD.
From what I think to know, a pound is a little less than half a kilo, which would mean some 9 kg less to go - which is just not the way you want to go when you're already where you seem to be (photo).
Are you sure you didn't mean to "Tweet" that or Facebook post that instead?
:lol: Thanks everyone, but yes. I want to lose weight. A couple reasons, but mostly because I don't like how I look *quite* yet.
Oh, and I'm 6'1".
Dude if you lose 20 more lbs there will be nothing left.
6'1'' and 130 pounds is really slim already.
Remember that healthy is the most important.
No way ur 6'-1"!!! I'm 6-1 and if I were 110 lbs I would look sickly. Instead of losing weight try putting on some muscle.
Hmm....yeah...I don't know your body type or genetics but just from a pseudo-scientific point of view 18.5 is the BMI at which you would be considered underweight, and at 6'1 and 110lbs you'd have a BMI of 14.5
Your body might be able to handle it, idk, but when I got down to 135 last summer from working out a lot I started getting headaches and being tired all the time.
I think that would would be a healthier solution (and this is just a suggestion, I'm not telling you what you should and shouldn't do) is to build up some lean muscle, because then your body will have definition and you will be lean and thin but not at such a low weight. But if you're going for the really slender look then disregard this post. lol
EDIT: Oh, you're 130 right now. I thought you were 120. I DO think that 20 lbs is a bit much, and considering how skinny you already are that 20lbs loss will really be noticeable.
coupla curls and bench presses mate followed by push ups and weight hurls. Then get into the chicken and pasta!
Oh and the bacon before it runs out!
1kilo is around 2.205lbs
