35 mm Equivalance ...meaning
Yikes, I missed the fun post this time. :o
For me, I really don't care about the crop factor. It is simply because the camera I use is a cropped body. And my first SLR camera also a cropped sensor digital body.
I have no experience with the film nor the full frame sensor. So, the equivalent focal length (FoV) means nothing to me. So when I use my 50mm lens and that is equivalent to a 80mm (FoV) ... and so what is that mean? It mean when I use a 80mm (if exist) lens on a film camera, the FoV should look the same. But I am not using a film camera, why should I care? :D Why should I need to worry about what it will look like if I using a film/ff 35mm camera when I am only using a cropped body?
I think after I familiar with the cropped body FoV, so when I move to FF, should I need to worry about Full Frame Factor? My 50mm lens is a 31mm lens (FoV equivalent).
I think the crop factor is only for people who are coming from the 35mm film. Since they are familiar with the FoV of the existing lenses / focal length, so when they jump to Digital body with a smaller sensor, they know what to expect when mount a lens on the camera.
So OP, if you are not used to one system, you do not need to worry too much about the crop factor stuff.
If you move to a full frame camera and your lens is a dx lens then you will have an issue, as it will not cover the sensor . WIth Nikon , they automatically adjust so you are then only using the center of the sensor, which isn't always bad,
