ok... ive read in one of my mags a guide on how to keep your landscapes pin sharp all the way through.... and for the love of god can I find it again?... "yeah right"
well, i remember something about manual focusing one third up, and using some DOF chart or something to set your distance to something else of something else... and yeah, im confused... and cant find the mag, and im going crazy! arrhrhhh!
can someone please explain it to me if you know what im baffling on about.
thanking you!
That is an ideal that is not very realistic in most landscape shooting, even by professionals. A fast shutterspeed often gives you a narrow depth of field or area of focus. A small f stop like f16 gives you better depth of field but a slower shutterspeed, often requiring a tripod. If there is a wind, trees, flowers, grass may be soft focus due to movement. In the distance haze also distorts colour and takes away from pin sharpness despite your settings. Filters can reduce haze but they do not completely eliminate it. There is usually more contrast in the scene then what your camera can handle, so even trying to retain some detail in the highlight and dark areas is a challenge that requires postprocessing, let alone any hope of pin sharpness. The limited dynamic range of most landscapes in shades of colours also limits sharpness.
To top everything off, according to one technician that I worked with on a project, any photography for commercial duplication by the company he works for, requires pin registration adjustment of the camera in his lab for accurate camera focusing irrespective of make and model of the particular camera.
In terms of best digital camera sharpness, one lab study was so specific that it indicated that Canon was best with regular geometric shapes in buildings or objects for example and Leica was best in the irregular shapes that are present in nature like leaves, trees, rocks, ground, water etc.
So, a Leica with pin registered focus done in a lab, on a tripod around sunrise or sunset with cross lighting or a cloudy day with diffused lighting shooting a landscape with no haze, limited contrast and dynamic range and limited motion might ,with ideal timing, come remotely close to sharpness throughout ....but not highly likely. Even if it were accomplished the shot might end up boring from a visual perspective because of the limitations.
skieur
