Adobe illustrator CS5
pedro.silva
Adobe illustrator CS5 just crashed and I hadn't saved my work...is there any way to restore?
Hello,)
Illustrator create temporary files ending in " .tmp " for example #####.tmp in Windows; or Temp##### XXXXX aMac.... (### XXXXX XXXXX of numbers)
Look for a file ending .tmp in the folder where your file is saved, try open opening these in illustrator.
If the .tmp file is not present Then I'm afraid the news isn't good. Unfortunately there is no automate feature in CS5, so regular apple+s is one option. Or alternatively, you could try something like this: Autosave in Adobe Illustrator Using the Actions Palette - Envato Tuts+ Design & Illustration Tutorial
Or try this utility Illustrator Recovery Toolbox. May be some data be able to recover.
https://www.oemailrecovery.com/illustrator_recovery.html
I hope my answer helped you.
Thank you guys for your feedback and help. Sorry, that long time did not respond. This is because the issue was solved and I forgot to tell.) Thank you!
