Amature photographer needing some help
Amateur
For a blurred background - Understanding Depth of Field in Photography
and all of their other really good tutorials - Digital Photography Tutorials
As far as GIMP -
Beginning GIMP: From Novice to Professional
GIMP 2.6 for Photographers: Image Editing with Open Source Software
Which version of Adobe Photoshop? The professional version, CS5? The consumer version, Elements 10? The suppliment to CS5, Lightroom 3?
The Photoshop Elements 10 Book for Digital Photographers (Voices That Matter)
Buy a prime lens with a large aperture like 1.7 or 1.4. Take picture. Then increase the color saturation.
You can find tons of tutorials for gimp just google it. :)
You don't need a prime lens with a large maximum aperture to get a shallow depth-of-field, but you do need to know how to control DoF to your advantage.
People cannot see infrared (IR) light.
A digital camera can be modified so it only records inrared light, which can be made into an image we can see. Or, you can put an IR filter on the front of your lens, the only trouble is, if you look through the camera's viewfinder it's enitrely black to your human eye. So you have to set up the shot, focus, put the filter on, release the shutter. Then rinse and repeat for each new shot.
Thank you that really helped I will look into getting an infrared filter!
No, but it makes it alot easier to control as what you are implying.
It is also possible to have a camera converted to shoot in infrared but its a bit pricey and that would be all you could use it for then. but the results are much nicer imo.
Yep. A camera converted so it can only make IR images is head and shoulders easier than using an IR filter.
The camera conversion can be done DIY.
