Another assignment
terri8 2
Administrator
Staff member
Supporting Member 📸
Off the top of my head, I can't recall what this photo assignment was called, but I think the main object was *opposites,* or extremes. (From a college photo class I took to get access to their darkroom while mine was still in boxes!)
This is one of the rare occasions I had to be my own model to get the point across. I usually avoid this at all costs. The first image is the "angelic" model, and the second is... less angelic.
The darkroom development played a part: for the soft image, I used the old *pantyhose stretched over the enlarger lens* trick for diffusion, and it's about a Grade 2. The other image, no diffusion, and at Grade 3, the increased contrast to make it grittier.
I had no makeup on for the first shot. For the second, I piled it on, smeared it, messed up the wet hair, and held a cigarette I had lit outside and extinguished. (I'm not a smoker, so I had to buy a pack of cigarettes for the shoot and had no idea they were so expensive.)
Anyway, the extra work for me made it fun. Comments welcome!
It would have been cool if the cigarette was lit in the second shot - veiling your face with smoke in a similar way to the fabric in the first shot.
Good stuff.
The 2nd picture I like very much, the contrast looks great to me. The softened effect in the first is a good technique, thanks for the tip!
The second image wants badly to be Draganized. :)
Thanks for sharing. I like the results--they're good.
Now...here's how you could have enhanced them...
1. Visually create more opposites. The first photo is light, not quite high-key. Make the second photo even darker, half of your face in shadow (and yes, the smoke is a good technique). Or one with a narrow DoF and one with a wider DoF. What you did was shoot opposites of YOU (good/angelic Terri, evil/mean Terri). Think of how to make visual opposites too.
2. Express emotions or feelings so that both photos so more contrast. In the first you smile more and hold a stuffed animal. In the second you look grim and you stick the cigarette in to the stuffed animal.
I'm just glad to "meet" you :)
  • Thread Starter 🔹
  • Admin 🛠️
  • #7
Good stuff.
You know, I actually considered that very idea. But, ended up deciding to be more directly in-your-face with that one. :) Thank you!
You are very welcome, though it's a very well-known darkroom trick for quick & dirty diffusion. But thanks!
I had to go look that up. :lol: And I saw another thread where you have been experimenting with this technique, so I can appreciate where you're coming from. I think it stands well enough as it was developed in the darkroom, and tend to avoid photoshopping any of my work - but thank you for the comment!
Great suggestions, Joe. Although I don't know about sticking a stuffed animal with a cigarette, but appreciate the added drama it would give. ;)
I stuck with very minimal props, and just thought the veil was suggestive of timidity (to hide behind) and innocence (like a bridal veil), and the cigarette combined with the makeup and higher contrast grade, was sufficiently coarse. But clearly the concept could have been expanded on in a number of ways. Having assignments makes you get creative in ways you wouldn't normally consider, and having time pressure was a bit of a drag. But thanks so much for sharing those ideas. :icon_thumbsup:
:icon_hug:
Loooooove these! :)
