- Joined
- Jun 7, 2012
- Messages
- 15,480
- Reaction score
- 7,862
- Location
- Central Florida
- Can others edit my Photos
- Photos NOT OK to edit
- Moderator 🛠️
- #1
I saw that the wife had some leftover peel back foam on the cutting table, so I figured, what the heck...
whats the worst that can happen? this was by no means a professional job, and i think the foam is a little more compact than what was in there before (what little was left anyway) but the film door closes fine, and i cut the foam to the same dimensions as the old foam was. I believe it should work as well as the original. i did not replace the mirror foam. yet.
here is the before, after i scraped the old foam out. then i used some rubbing alcohol to clean the surface.
a piece of the foam the wife had lying around.
the foam cut down into the two side strips. its more or less accurate. I used a ruler and rotary cutter.
after i got the pieces in. I took this shot, then realized i had to a little more adjusting to the foam where it had gotten pushed out of place a little.
Not quite as bad as i had thought it would be. might have been a little easier with the "proper" foam, but i think for all intents and purposes, it will do the job just fine.
