Auto ISO with manual mode. Am I making a mistake ?
nixgeek
Hi All,
I'm using a Nikon d810, and my go-to default setting is to use auto-iso in manual mode. I can quickly change the aperture and shutter speed, which are the most common variables I change when having to quickly pick up my camera and get that moment.
Obviously, the camera then sacrifices the ISO to get a decent exposure. For more planned shots, like astro or landscapes, I'll use manual ISO as well, but it's a luxury I don't always have when the kids decide to do something funny there and then. I'm fortunate to use chunky glass f/2.8 stuff (it's good for the biceps at least :)) , so it's not often it takes me past iso 3200 which the camera/lightroom can deal with.
Finally, the question....
I've read in a number of places I should be using either full manual, aperture/shutter priority and I'm really keen to hear of others experience of auto-iso and if I've overlooked something important.
Thanks!
Auto ISO is my SOP. Dial in the aperture and shutter speed I want for the shot, and let the camera choose the ISO.
Cameras and editing apps are getting so good with higher ISOs these days that shooting with it isn't much of an issue. Back in the day, shooting ISO (ASA then) 400 or more was pretty much crap. Nowaways, it's 6400 or 12800.
Yep provided that the light is manageable for the built in meter to work with (with or without some compensation from you) then its a valid approach for ok lighting where you're not worried about the ISO and where your shutterspeed and aperture are far more important. If all you are going to to do is raise the ISO anyway then let the camera do it - its faster than you will ever be. Of course ilke all automatic elements keep an eye on it, bare in mind the scene and how the meter will read it (eg if you're shooting all snow the camera will underexpose if left on its own to expose the scene).
As long as you're judicious about the shutter speed and f/stop choices you make then auto-ISO is fine. If you're sloppy and select a shutter speed that's 3 stops faster than you really need the camera has no choice but to exchange those three stops for increased ISO. If you just want to be able to grab the camera point and shoot you can set auto-ISO and leave the camera in Program mode -- the camera will try and optimize all three variables. But if you have time to take the photo deliberately and you're setting the most appropriate shutter speed--f/stop then auto-ISO makes logical sense.
Joe
Joe
I see what you are saying about the f-stop. I've had the camera for a while so I can usually guess the f-stop required within a stop. If I've screwed up and it's beyond my desired iso it flashes red on the image to warn me that I've been a muppet. Thanks though, it makes sense.
Agree with all of the above. Manual with auto ISO is my go to mode unless I'm in the studio.
There are a couple of reasons people may say this. Sometimes it's to ease people out of the dreaded green auto mode but more often than not it's narrow minded people that think there's only one way to shoot. I generally ignore anyones opinion that comes with a blanket statement. Yes I see the irony in that statement. lol
As for what's right for you. It's always fun to experiment with new settings/ways of shooting but in the end go with whatever mode you are comfortable with and gives good results.
I use that setup a lot, it's also my go to setting for general shooting. Dead easy to then bump the shutter speed or aperture from there.
I find that there's very few situations I shoot in where I don't want to control both and my camera defaults to 1/60th sec or wide open far too easily.
Shooting in full manual I prefer, but sometimes there's just not the time to set up shots.
Depends on what you're shooting. If you are in a studio like setting with controlled or consistent bright lighting set your camera to base ISO (best color depth and SNR), I usually use A mode for still subjects to blur the background when desired, and S for things that are moving to freeze the subject. For landscapes, base ISO, A mode with a high f stop for greater DOF without refraction, and I don't usually care about the shutter speed unless I've got water or clouds moving. For wildlife, especially birding, manual mode, usually open aperture or one stop up, shutter somewhere around or above 1/1000, auto ISO from base to about 1600. For fast birds, like songbirds, I'll be at 1/2500 sec. Sport, same as wildlife / birding except shutter around 1/500 or 1/800. Don't get locked into a specific setting. Use the right tools for the job. So here's my exception, I always, always use BBF.
It goes get pretty annoying when you're trying to expose for something specific and you don't use AE-L. I used to use it a lot, and have used it less and less over time.
With a class leading performer like the Nikon D810,or a similar full frame camera such as the D 600 or 610, or D 800 or the D850 The ISO performance is so good that I personally think auto ISO in manual mode is the default Mode that more people should explore. You have been given solid advice above by several very competent shooters. For non-flash and non-studio situations and rapidly changing lighting conditions, auto ISO with modern Nikon cameras is very usable. A decade ago iso performance was a constraint, But with cameras such as yours ISO performance is now so good across a wide range of settings that it makes sense to use automatic ISO setting,especially in certain conditions.
Joining the crowd - this is the way I shoot most of the time for action, landscapes, kids, animals, nature... unless I'm using my tripod or I have a specific need to keep the ISO low. Auto ISO is a pretty common setting especially in dynamic situations where you don't have time to adjust before each shot.
About a year ago I taught a beginner how to use Auto iso with her Nikon D3200,and for her it was a revelation.
She had unfortunately been instructed by A person who I considered to be a poor teacher, to use Full manual, which with a one-button camera like the D3200 is more difficult than with a two-button intermediate or high-end camera.
Once she was shown the idea of picking her desired aperture and shutter speed and allowing the camera to adjust the ISO upward or downward as necessary, she was able to shoot for an entire day with very little effort, and to concentrate upon composition and timing more than on futzing round with her camera's fiddly settings.
Yep go back 10 years or so and ISO performance dropped off fast as you went higher and it was far more important to keep an eye on it, so using auto wouldn't have been much of a benefit to photographers. Today where you can easily get to 3200 or higher without huge detriment to the exposure quality; and where nikon has invariant sensors which don't even mind some underexposure; then auto gets far more practical for the ISO!
In fact as digital has continued to advance its become clear that if ISO performance keeps going at its current rate we might well reach a point where the only time you might have to change it manually is in flash dominated lighting where you want the camera firing on a specific exposure every single time without variation.
At one time even high-end cameras offered very poor middle and higher ISO performance. My first good digital camera was a Nikon D1 in 2001 and it was not that good a camera above about iso 200.today? We get good pictures at ISO 12,800!
