av mode in night time help!
thank you pgriz, my main problem was that my flash would not go off in av mode so I switched from af to mf to take pictures
Most likely what happened there is that the camera couldn't get a AF lock because the light level was too low, and some cameras do not allow you to press the shutter if the focus lock wasn't achieved. By going into manual focus, you "told" the camera that you're looking after the focus - so it says, okie-dokie, I'll open the shutter (and fire the flash) any time you press the shutter.
The answer is Yes/No/Maybe/Depends.
Yes, it will let in more light to the sensor, at a cost of a thin DOF, and probably you will still need to boost the ISO or use some form of flash or additional light
No, by itself it gets you only 1-2 stops extra of light,
Maybe, because together with other techniques (higher ISO, tripod, additional light sources) you may get enough light even with a slow shutter to show the detail you want to show
Depends, because if the subject is moving, you probably can't use a tripod, and are now needing either more light, or higher ISO or both.
An "average" interior lighting level (EV 5 at ISO 100) would require 1/8 sec at f/2 at ISO 100, 1/30 sec at ISO 400, and 1/60 at ISO 800. Shooting 50mm on a crop camera, and using the "rule" that hand-held shutter speed should be no less than the reciprocal of the focal length, your minimum shutter speed would be probably 1/60 sec. That means that if you shoot your 50mm f/1.8 lens wide open, you'd need to bump the ISO to at least 800, to be able to shoot at 1/60 sec. At that aperture, if your subject was 10 ft. away, your depth-of-field would be a little under 0.8 ft. (about 10") "thick". So, you will get most of a person's head in focus, but not the person standing behind them or in front of them. If that's unacceptable, then you will need to increase the aperture to f/5.6 or even f/8, which means a loss of 3-4 stops of light. If you had a 5DIII, you could boost the ISO to 12,500 (4 stops from 800), and get decent images. Can't do that with a Rebel. So then flash becomes the way forward.
To recap: f/1.8 will allow you to shoot at 1/60 sec at ISO 800, with a rather thin Depth-of-field. If that's what you want, then yes, it will allow you to take the picture without flash. But you will have some noise in the images, and the depth-of-field will be shallow.
