Battery Grip Problem
Link Delight Online Shop
Official Vendor
Supporting Vendor
I heard that battery grip can help extend the shutter speed, mainly to extend life time, when you forgot the charger it is really useful. I want to consult an experienced expert, this battery grip could have? Actual results? Must I have to buy the original battery?
Note: I have only one battery, and intend to install the 5th battery. If I buy original battery, then that could cause the high cost of batteries.
$bg-d7100_lr_sq_1.jpgbattery grip for Nikon D7100
I heard that battery grip helps extend shutter speed, mainly to extend life time, when you forgot the charger it is really useful. Consult an experienced expert, this could have? Actual results? ? Must have to buy the original? Note: I have only one battery, which intends to install the 5th battery, if I buy original battery, then the high cost of batteries. <img src="http://www.thephotoforum.com/forum/attachment.php?attachmentid=63761"/>battery grip for Nikon D7100
What
I read this twice and I'm pretty sure I didn't understand a thing you said.
I heard that battery grip helps extend shutter speed, mainly to extend life time, when you forgot the charger it is really useful. Consult an experienced expert, this could have? Actual results? ? Must have to buy the original? Note: I have only one battery, which intends to install the 5th battery, if I buy original battery, then the high cost of batteries. <img src="http://www.thephotoforum.com/forum/attachments/linkdelight-photography-accessories/63761-battery-grip-problem-bg-d7100_lr_sq_1.jpg"/>battery grip for Nikon D7100
What
I just want to know the battery must be orginal?
thanks
A third party battery should work fine.
By third party I mean off brand or Non Nikon.
I hope that helps.
