+Is a lens cap holder good or annoying ?
TIA!
I have a car battery wired to mine so you should be fine. To clean my lenses I just spray them off with a hose. Lens cap?
:lmao:
I have had my fun for the day. Sorry OP I couldn't resist.
Re: battery grip, it depends on the shooter. Would you like for your camera to be a bit heavier/bigger? I use a t2i regularly and it's a decent sized camera, but the grip gives me something to hold on to (hence, "grip").
Google lens cleaning, plenty of youtube videos.
Lens cap holder? The sticky thing with a string on it? Annoying as hell!
I have Canon battery grip. But I have not use it for couple years because of the weight. It is simply because of my hands. (After using keyboard and mouse for so loooonnnnnggggg now) If weight is not an issue, I like the grip. You just need to try it and see if you like it or not.
As for the lens, I clean it with a lens paper and lens cleaning solution if needed.
The front element of this lens was cleaned with lens paper with lens cleaning solution. The liquid help remove the oily finger prints.
http://farm3.staticflickr.com/2530/4113289657_17e5345e3a_z.jpg?zz=1
Most people find that a battery grip improves their photos. The reason is that it gives them more/better gripping surface and thus they hold the camera steadier. This is especially true when you rotate the camera into vertical/portrait orientation because the grip gives you an extra set of buttons.
What do you mean by an extra set of buttons?
Battery grips have a duplicate set of controls on the bottom which allows you hold and operate the camera conventionally when shooting in portrait format.
Oh ok I didn't know about this feature thanks.
