Bottom line...whatever works. Or, whatever is best for the situation.
Your post didn't indicate if there are any subjects, lit, unlit, back lit, front lit, internally lit (houses, for example), etc, that you wish to capture in the photograph. If there's a particular person, for example, back to the dusky blue sky that is reasonably lit, then use spot metering. If you are trying to capture the blueness of the sky and everything else in silhouette, then matrix.
But, metering or not, it really doesn't matter. It all comes down to determining the appropriate exposure for the situation. I'd definitely start with Av mode (or whatever Nikon calls aperture priority) to establish what I wanted for depth of field considerations. Given a couple of test shots, then it may be necessary to crank up the ISO speed to get what you want. Lastly, figure out what shutter speed is needed to get your shot. Assuming you are photographing something more or less stationary, a shutter speed of 1/30 or even slower may be called for...if the camera is on a tripod (recommended for low light shots!). Hand held, 1/<focal length> is a good starting point, but may result in a too-fast shutter speed to get a good enough exposure. It's trial and error, several cycles, before you'll arrive at the settings you want. But then, a minute earlier or a minute later, it's all changed...
