Newtricks
- Joined
- Aug 15, 2013
- Messages
- 607
- Reaction score
- 104
- Location
- Cali4nia
- Can others edit my Photos
- Photos NOT OK to edit
2 lbs fresh ground beef, browned in olive oil
1 large white onion, chopped
2 celery stalks, chopped
8 garlic cloves, pressed
1/2 C. chopped flat leaf parsley, chopped
1 Tbsp each dried Marjoram & oregano
1 Tbsp each allspice, coriander & cumin, toasted in a dry pan and ground
ground ancho, cayenne, and chipotle pepper to taste
Smoked Spanish paprika, also to taste
1 28oz can peeled tomatoes, crushed by hand
Heat a large pot over medium high heat, brown the meat in olive oil in small batches so as to not over crowd the pot, drain and set aside.
Pour fat out of pan add olive oil, onion and celery cook until well browned, add garlic and parsley and cook until the garlic is fragrant (about a minute), add this to the beef and set aside, deglaze the pot with 1C (I use Knob Creek) bourbon and cook until it has been reduced by half before pouring the bourbon into the beef mixture.
Pour the tomatoes into a large bowl, add 1/4 C. bourbon to the tomato can and rinse it out, into the bowl. Crush the tomatoes in hand, be sure to hold them under the liquid or you will be wearing tomato on your shirt (I know this for fact), if you taste the tomatoes at this point you will be put off because of the raw bourbon flavor, it needs to cook down.
Combine the tomatoes with the beef mixture, bring to a simmer over medium-low heat, reduce heat and simmer for 2 hours, adding liquid as needed. At this point there's plenty of bourbon flavor in the chili, I use water or a bit of dry red wine.
I season (salt & pepper) as I go, meaning the beef is seasoned as it cooks, the veg gets seasoned as it cooks then check the seasoning just before serving. I serve this over spaghetti or with cornbread.
