Brazilian Jiu Jitsu, Low Light, and Tight Spaces
Ballistics
I took some pics of my teammates and figured the flash would serve well but when I tried to bounce the flash it was as if the ceiling absorbed it in one spot so I just went with the 50mm 1.8 which was to tight but the fastest lens I own. Here's what I came up with.
1 by Compressed Memories, on Flickr
2 by Compressed Memories, on Flickr
3 by Compressed Memories, on Flickr
4 by Compressed Memories, on Flickr
This is the first time ever shooting in this gym and the first time shooting this sport. It's a relatively small school so angles were tough to get, especially since I was using my 50mm.
What would be the reason why I couldn't bounce the flash?
Most likely, your flash isn't powerful enough to cover the distance. How high were the ceilings? Secondary reason could be the ceilings were black...can't really bounce flash off a dark ceiling.
The walls are probably 7 or 8 ft high maybe? I have the yungnuo 467.
Your flash is not powerful enough to bounce for this sort of shot, here's one where i used a 400watt studio light with a large reflector fitted bounced off the high ceiling
Iso 1250 (to keep the background same exposure as restlers) 1/250 (max sinc) F4
Does the fact that the walls are all black affect anything?
Black absorbs light. That is what makes it black.
If you can't bounce, you will need to use direct flash with exposure compensation turned way down. Or if using your flash in manual, turned to a low power.
Exposure compensation?
Edit: Nevermind I found it in the flashes manual. How would I use the meter regarding direct flash?
I think the thing that would help these the most is paying more attention to the background. #3 is the strongest shot because the background doesn't distract from the subject (with the exception of the kid sitting on the right). The soda machines and mirrors completely draw away attention.
The cieling was black but What color where the walls? I see some black and a mirror. Can you trigger your flash off camera?
Jack the ISO value UPWARD is you need to bounce flash off of a black ceiling...or try bouncing the flash off of something light-colored that you can tack to a wall...or forget bouncing the flash...
