Building Car Rig
Keedo
Chicago IL
Piping I figured out, as well as mounting the camera to the boom/pole at the end. Right now I am trying to figure out how to connect the suction cups to the clamps. I am getting these suction cups, the worst part is that they have 1/4" screw. Alan Gordon Enterprises Super Grip Junior 1030-WO-TL6AMB B&H
I have heard bad stories of the F1000 failing.
The suction cups are slowing me down because I do not know how to find a way to mount them to the clamps. The suction cup closest to the camera, I would like to have it raised up, like an extension from the suction cup to the clamp to raise up the pole/boom so I can get higher shots.
Someone help me?
Machine a plug for the end of the tube (go about .0005 over) and then end and cross drill & tap 1/4NC.
The on car camera mount I use has 4 suction cups on 3 aluminum plates totaling 12 cups. Each plate has a center mounted bolt which I can connect varying lengths of alumining rods. I have an adjustable tripod head with a mounting plate.
Someone help me?
They have the 1/4" screw?
Manfrotto super clamp with 1/4" 20 stud.
Manfrotto 035RL Super Clamp with Standard Stud 035RL B&H Photo
I use two of theses on the f1000's to clamp my pole and one on a magic arm with camera bracket for my camera. Works great.
Manfrotto 143A Magic Arm with Camera Bracket 143A B&H Photo
Someone help me?
How do the f1000s do? I have heard that arent good and have a low load capacity limit.
Someone help me?
I know of a lot of people using them and they don't have issues. You have to make sure the surface is clean and it's best if it's wax/product free. I have a fairly heavy rig right now with a 5D MKII and 17-40 normally on the end and most of the time my issue is that it's a real pain in the ass to remove them afterwards. But, I tend to stay as close to the camera as possible, always check the pressure on the cups, have my boom wrapped in foam insulation, and watch it like a hawk. **** can happen with any setup. There's also the possbility of user error with trying to suction up a dirty car or a curved surface where it can't get a good grip to begin with.
