Buying a camera with a new shutter?
RxForB3
Yakima, WA
I'm looking at a 5D Mark II that has a new shutter as of last summer. Any reason to be wary?
Check the over all condition of the camera. Canon has had issues with inconsistent shutter life for years and years, though it seems they have gotten a better handle on it over the last 2 years.
So is a replaced shutter expected to last as long as a new? Longer? Are there adding internal parts other than the shutter I should be worried about? To me, a replaced shutter means the camera was probably heavily used, but in what setting...
I'd ask if it was mainly used for Video or Stills. I am shying away from anything that was mainly video use. That's a lot of heat on the sensor and makes me a little wary.
Will do! Thanks for the suggestion.
The shutter is a moving/mechanical part and thus will wear out over time and need to be replaced.
Would you buy a used car that had had it's tires or brakes replaced? Of course you would....it's usually a perk, not a red flag.
That being said, if a camera has seen enough use (or hard enough use) to need a new shutter, you would want to inspect it carefully.
That's what I was thinking, but I figured it was more analogous to a new engine...
In any case, the person appears to have changed their mind or sold it to someone else with having the courtesy to just let me know...oh well...
