Scatterbrained
- Joined
- Apr 19, 2010
- Messages
- 2,184
- Reaction score
- 1,083
- Location
- Yucca Valley, Ca
- Can others edit my Photos
- Photos NOT OK to edit
Rather than using the spigot mount to mount the griphead to the boom, use the actual clamping part; then just drop the baby pin through the spud mount hole. This gives you a lot more clamping force on the boom arm to keep the light from spinning so you don't have to hang it straight down.I use Speedotron Brown and Black line, and use Manfrotto boom arms, so I can put the mounting spigots into the boom arm either "on the pointy end-part", or "cross-shaft" mounted...maybe I am dense, but I do not quite understand why the Uni Jr. needs to be mounted upside-down...I have never had to mount a flash head upside down. What's the issue that necessitates this upside-down mounting?
Maybe I'm doing it wrong, but top-hung seems to be the method which "spins" the least. If I mount the Dynalite directly onto the boom's 5/8" spud (oriented horizontally), it simply won't hold any tilt-angle (the Dynalite's baby screw just won't tighten with enough tension). Although I think I know what you mean by "cross-shaft," do you have a picture you can post of that? Thanks!
