Aside from that I think I will definitely consider the AF-D Push/Pull for my D7100, I think for now, that lens is the best bang for the buck.
For those that use this lens, I'm told that the lens is slow to focus, but how is it when prefocused?
I just looked this up: AF Zoom~NIKKOR 80-200/2.8 ED: 16 elements/11 groups, 3 ED elements., 2 lbs 10.3 oz-NO TRIPOD ring, ONE ring design.
2-Intro in 1992: the AF-D NIKKOR model of the 80-200/2.8ED: different limiter switch, 3.5 oz heavier.
3-AF-D NIKKOR 80-200 "two ring". Introduced Photkina 1996. NEW is an L-shaped tripod mount. 16 element design, new limiter switch design.
4-AF-S Zoom~NIKKOR 80200 f/2.8: Introduced at Photokina 1998: 3lb 2.8 oz without tripod bracket. Silent Wave focus motor focuses almost instantly;three "Focus Lock Buttons" on the lens barrel. NEW 18-element in 14 group optical design features Five ED-glass elements. Aperture diaphragm is now rounded, with 9 blades, for better out of focus rendering. Build includes aluminum casing and carbon fibre materials; this lens is compatible with Nikon's TC14e, TC17e, and TC20e AF-S type converters.
and you would spend alot more for the vr2 version than an older model too, which seems to be a major concern to the OPSo from those stats the afs version should be a little better optically, but sure couldn't detect a difference.
One thing for sure you will get more CA than you get with a new vr2 lens.
djacobox said:So from those stats the afs version should be a little better optically, but sure couldn't detect a difference.
