Buzzzz Buzzzzz C&C please :)
myluvtat2
Charleston SC
These were shot with my Nikon D3100 and 18-55mm kit lens. I am not sure the settings (how do I find that :blushing:)
TFL!!
In this one I wish the entire top of the flower were in focus...I am working on focusing.
Is this crop too tight?
You can right click on the image in windows viewer, then click properties.
Should show you the details of the image.
Whatever imaging software you're using should also show exif data.
Aha! Thank you :)
1-1/2500 shutter speed, f/5.6, and ISO 400
2 & 3-1/1600, f/5.6, and 400
So...I needed to raise my f-stop in order to get more of the flowers in focus right?
C&C per req: I think given the lens you had, these turned out very well. Depth of field in close-up work is very challenging. In fact, when working in extreme situations, it can often be less than 1mm! One of the keys is to ensure that the important area is in sharp focus, because often (usually) you can't have the whole image in focus (Without special techniques and software; search "Focus stacking"). I think the crop in #3 is fine; the only issue that I see with any of the images really is that the blacks are under-exposed. Some additional lighting would have helped, but that's not huge.
Just my $00.02 worth - your mileage may vary.
~John
Aha! Thank you :)
Correct, and you're most welcome.
I also think these turned out nice for a kit lens.
Well done.
Aha! Thank you :)
Well done.
Thank you very much :)
I agree, impressive considering the lens. The crop on #3 is good, but the image quality is starting to suffer.... the noise is noticeable. You could have stopped your ISO down two stops and still had plenty of shutter speed. DoF look fine to me.
i agree... very nice ...awesome with that lens..
I also think you did well. However, you could have easily shot @ f16 & had a high enough shutter speed & you would have gotten a lot more DOF.
Thanks! These pointers are awesome. I can't wait until the day that I *know* what settings to use for each shot. Right now I am still just playing around with different settings and getting lucky when I get a decent shot. It helps so much to have good advice/feedback.
