C&C- Early Morning Waterfall Landscapes
nmasters
Georgia
Hey gang,
Just a couple days ago, I was in ankle deep water at 7 AM photographing this beautiful waterfall.
The waterfall is located in Roswell, Ga, about an hours drive north of Atlanta.
Shot with a Nikon D5100, and 18-55mm kit lens.
#1 ISO100, 18mm, 2 sec, f18
Water4 by nico418, on Flickr
#2 100, 18mm, 2 sec, f11
Water2 by nico418, on Flickr
#3 360, 18mm, 1/125 sec, f3.5
Water33 by nico418, on Flickr
#4 "the money shot" 100, 22mm, 0.6 sec, f11
Water by nico418, on Flickr
I like two the best, though I think it was tilted every so slightly to the right, probably a little bit cold and had a tiny bit of a green tint (or perhaps I just like landscapes warmer), and perhaps could use a little bit more contrast. Here's what I came up with as far as an edit goes, Take it or leave it, YMMV :)
showingediting by franklinrabon, on Flickr
Basically just added some warmth to it, some contrast via curves, dodged the areas where the sun was hitting the leaves directly a bit, and burned the areas that it wasn't a bit to help give a little bit more directionality to the sunlight. The blown sky bothers me a little bit, but there's not much you can do with it without blending exposures, most likely.
Nice scenic shots you got there. That could be a really spectacular place to return to several times for different seasonal shots.
Sky didn't help but I like #2 a lot.
http://www.flickr.com/photos/franklinrabon/7557082796/
Thanks for the edit! I really like it, what software did you use? I used Lightroom 4.
What else could I have done to prevent a blown out sky?
I use Aperture (I use photoshop for some things, but this was all aperture).
You really probably couldn't have done anything about the sky without taking multiple exposures and doing HDR or exposure blending. To get the sky exposed properly, the rest would be so massively underexposed that it would be really noisy if you brought it up in post.
or used a gradient nd filter. ;-)
Problem with that is the trees would be too dark. gradient ND filters only really work when you have a fairly even sky, not a v cut opening.
"reovery" may have helped a little. Or just simply patch in a good sky, would take a little work and obviously would taint the photo being yours but for such a small area it would be worth a shot.
I do like the photo's none the less though, nice area ya found there.
