Why don't camera's simply have a flashlight to shine a steady stream of light that isn't as bright as a conventional flash on a camera? Is the point that the bright flash is timed so that the bright light doesn't interfere with the picture quality? But, wouldn't a hypothetical flood light mounted atop or below the camera, and away from the lens so as to not cause any glare and other negative lighting effects, do just as well? Video cameras use flashlights...
Or is it by convention that burst flashes are used instead of a lower intensity but steady stream of light is used instead?
Do flood flashlights made for cameras exist?
Thanks in advance!
Thanks in advance!
