Camera Shopping- Need Recommendations
TriPaC87
Joplin, MO
Hi everyone. I'm shopping for a DSLR camera. I've found myself in more situations than I like where I wish I had a high quality camera to capture a moment. I would like to find a camera that covers as many of my needs as possible. I will be shooting just about everything... family photos, portraits, indoor sports, outdoor sports, sunrise/sunsets, boating, and nature. I also find that I enjoy candid shooting at weddings. I am assuming I will need multiple lenses, which I am okay with. I just want to make sure I am buying a camera that I can use for years to come. I hope to find a good deal on Black Friday so I have 10 days to figure out what I want. Please share your recommendations! And bear with me... newbie here!
Thank you so much!
Tristan
Everyone will tell you something different. Its all a personal choice. You aren't going to find any of the top of the line cameras discounted on Black Friday but you may find entry level dslr cameras on sale on Black Friday. I know that price is a factor for most people, but do yourself a favor and go to a store, try out a few models and make your decision that way. Get online and research models that you are interested in, get the specs... don't choose on price alone.
There are going to be a million and one questions regarding a camera on Black Friday.
However the the best looking value is from Best Buy for a Nikon d7000 with 18-140 for 799.
Price isn't really an issue. I want to narrow it down to a few cameras and then I will research each camera and start shopping.
It'll be really helpful for you to go hold some cameras & play with the menus and settings to see what you like. Some people find that they "get" the way one brand or another does things, or how one camera or another fits their hands. If you want more specific recommendations from people here, we should also know what sort of budget you've got, what sort of research you've done, what actual features are important to you, and what you're planning to do about lenses. In the absence of that sort of information, virtually any DSLR on the market could potentially meet your needs.
Thanks for the recommendation. Looking at that camera now!
Thank you so much!
Tristan
Ok, generallly I recommend you set a budget first and work within that, but since you mentioned in a follow up posting your not considering budget yet, for what its worth:
There are a lot of different DSLR's to chose from, generally I recommend you stick with either Nikon or Canon to start with - nothing against Sony, Pentax, etc - they make some fine cameras. However the strength of the used equipment market for Sony/Pentax is generally not as strong so generally speaking I think your better off looking at Canon or Nikon to start with.
As to Canon vrs Nikon, I chose Nikon because of the two when you compare cameras in the same class Nikon will almost always give you the better image quality. Canon's advantage generally lies in larger buffers and slightly higher frame per second shooting speed, but the differences there are normally not a huge difference. So of the two I found Nikon a better fit, since the vast majority of what I use a DSLR for is still images and image quality was the most important factor for me personally. That having been said a lot of people use Canon, love Canon and prefer Canon, but since I'm a Nikon guy I'm going to speak about Nikon. I'm sure folks who shoot Canon will weigh in as well to give you more information on their choice.
Since your looking for a entry level setup I'd recommend you look at the 3x, 5x and 7x series. While Nikon does make a lot of full frame offerings the full frames are generally more expensive and given the types of shooting you said were of interest I think you'll get the best return on your investment by staying with DX rather than FX, at least for now.
The 3x series, D3100/D3200 are very nice for entry level photographers, but I generally recommend them for folks that are going to be only taking pictures infrequently. They have a wonderful guide mode that will ask you some questions and do most of the setup for you, allowing you to concentrate on pointing the camera and clicking the shutter and letting the camera make most of the choices for you as far as settings. You can still do the manual mode if you wish, but really the biggest advantage to the 3x series is this guide mode so if your going to be getting "serious" about your photography odds are good after the initial learning phase you'll probably want to use manual mode and the guide mode feature probably won't get used much after that.
The 5x series, D5100/D5200 is a very good place to start for entry level - they are fairly inexpensive and allow you to have more budget to spend on lenses as opposed to the camera body, which in the long run is generally better - a really advanced body with a poor lens is not going to give you anywhere near as good of results as a less advanced body with a really good lens. The 5x series features an articulating screen, which can be very handy for lining up shots at odd angles. The 5x is a good all around camera with excellent image quality and good low light performance. I use a D5100 myself.
The 7x series, D7000/7100 are a little more advanced than the 5x series. Here you get weather sealing which is nice if your shooting outdoors in bad conditions (just make sure your lenses are weather sealed as well), two SD card slots, and a built in autofocus motor. The autofocus motor built into the body allows you to use the older, non AF-S lenses so if you keep an eye on ebay sometimes you can pick up some really great lenses pretty cheap, assuming you don't mind going used. The 7x series also has a lot of the controls you need tied to buttons on the exterior of the camera, so you can more quickly and easily adjust things like ISO or shutter speed without having to call up a menu system, which can be an advantage particularly in sports shooting. The 7x series does not have the articulating screen and will be more expensive than the 5x series.
Given what you've said so far I'd recommend you look at the 7x and 5x series to start with, I chose the D5100 because for me it was a great balance between price an performance, but if you have the budget a 7x series would be an excellent choice as well.
Nikon D7000 and D5100 are probably the best "value proposition" cameras, since they are one generation back, and cameras inventories have tended to be selling slow, so the stores are anxious to get them out the door. The D7100 has better specifications than the D7000, but costs significantly more. Still, a D7000, a last-generation body paired up with one of Nikon's VERY-newest lenses, the 18-140mm zoom, for $799 sounds like a tremendous deal to me, it really does.
Since you didnt specify how much money you want to invest in this purchase I will recommend you 2 cameras to choose from.
1.Nikon D610
2.Nikon D7100
If money is not a problem then the Nikon D610 is the camera I would go for, its full frame and does basically everything very well, the only drawback is that its not cheap, about 2000$ for just the body. Being full frame you get the benefit of excellent low light performance.
The second option is the Nikon D7100, the first benefit is that it costs about half of the D610, it is almost as capable as the D610 and actually has a more advanced AF system which means better for sports photography.
Being a crop sensor camera it is actually very capable in low light photography btu still not as good as a full frame camera so I would say the only place you would see a real difernce is in the low light.
Does it worth the extra 1000$ just for the extra low light capabilities ?
Well thats a tough one to answer since the D7100 in my eyes is the best crop sensor camera to date so I would say for a novice who has a tight budget then I think not, the Nikon D7100 will be more then enough but again if money is not a problem by all means the D6100 is the one to get.
I just want to add the Nikon D7100 is the camera that replaced the Nikon D7000 and if you consider the D7000 I would seriously consider the D7100 over the D7000.
The D7000 is a good capable camera (I know I had it) but the D7100 is better and newer, if you get a new camera might as well get the most updated camera and I think is well worth the 250$ price difference between the two.
Good luck
May I ask where you saw this ?
From my search it looks like the D7000+18-140mm VR cost 1599$ on Best Buy
Nikon D7000 Digital SLR Camera with 18140mm VR Lens Black 13310 - Best Buy d7000 &cp=1&lp=2
BestBuy Black Friday Ad 2013 - BestBuy Black Friday Ads, Deals & Sales
page 18
Pretty much this. Sure, there's reasons to choose Canon over Nikon and Nikon over Canon and Sony over both and Olympus for mirrorless etc. Each have their strengths and weaknesses.
Nikon D3x .... now price IS an issue.
best to think of a realistic total budget.
Camera
a lens or two
tripod
camera bag
but there's plenty of good recommendations above :)
Go to a store and play with them to see how they feel in your hand and whether you think you can understand the menu system or not.
Nikon, Sony, Canon, etc depending upon how much you want to spend.
Thank you so much!
Tristan
This is exactly what I needed to hear! I am leaning towards the Nikon. A friend of mine has the D7100 and he loves it.
