SoCalTiger
- Joined
- Mar 28, 2012
- Messages
- 135
- Reaction score
- 6
- Location
- Los Angeles
- Can others edit my Photos
- Photos OK to edit
So I tried to do this last night and it was pretty tricky. It seemed like my flash was just too powerful so I set the flash to 1/16th power and had someone hold it behind two diffusers about a foot from the diffusers. The diffuser was about 5 feet from the model and then the candles were in the foreground. I don't have remote triggers, but found out that even if I did that it wouldn't work. when I tried it with the flash attached by the chord and off camera, the candles just were way too bright.
So far what I settled on was putting the shutter speed at 1.3 sec on shutter priority and then releasing the shutter. After the shutter was released for about a second I had my helper pop the flash separately. That was the only thing that seemed to work okay but still not the results I wanted. Any thoughts? If these diffusers bareley dimmed the light enough, would a soft box even do any good?
Is 1/16 the lowest your flash goes? Lots of flashes go down to 1/64 or 1/128. Aside from that, do you have room to pull the flash further back?
