Mugen80
I will be taking a 35mm film class soon and wanted to get a recomendation on what canon body I should pick up. I would like to not spend more than 300 dollars if possible. Thanks in advance!
Well, I would stick with the EOS mount (not the older FD mount) if you plan on using the same lenses you use on your T1i. (The kit lens won't fit - the 50mm 1.8 will though.)
For $300 you can get a pretty good 35mm camera...
Canon EOS Camera Bodies - KEH.com
Don't be afrain to buy BGN grade - it's usually very good. I got a 1N RS for around $260 (I think...) there... That was BGN grade - looks pretty good. They have an EX+ rated one on there right now for $415. That will be pretty much brand new.
There's an EX+ EOS 3 on there for $245.
Dig around on there - there are some sweet deals. If you just want something for the class and don't really plan on using it much after that, they have a bunch of bodies for less than $50.
Somewhere on there they have a description of each grade (maybe if you click on BGN ... I don't remember)...Also what does BGN grade mean or refer to?
