Can't set my Aperture to lowest setting.
rfosness88
Whitewater Wisconsin
on my Canon 40D I have a Canon EF-S 18-55mm 1:3.5-5.6 lens. So shouldnt I be able to set my aperture to 3.5? It will only go down to 4.0. I tried Manual(M) and Aperture Priority(AV).
Thanks
3.5 is the widest your aperture will get when it is at the widest possible angle. As you zoom out the lenses aperture closes down to the 5.6. The aperture never changes really.
That's a variable aperture lens. Depending on the focal length the lens is at, it will be f/3.5 at 18mm and as you zoom out the maximum aperture will change until you're zoomed out to 55mm and f/5.6.
If it'll only do f/4.0 then the lens is zoomed out from 18mm a bit.
Yeah, zoom out all the way and try again.
