maxpower2001
- Joined
- May 1, 2013
- Messages
- 6
- Reaction score
- 0
- Can others edit my Photos
- Photos NOT OK to edit
Hi everybody,
I would say I already know most of the photography basics, I'm not really a beginner. BUT: I'm still struggling with one thing: Choosing an aperture.
I'm aware how the basics work:
When I'm out with my camera I have it set to aperture priority so the camera only sets shutter speed and maybe ISO. I understand most photographers do it that way.
Since I really like photos with a narrow dof I usually set the camera/lens to f/2.8.
My (many many) questions now are:
A lot of questions, I'm sorry about that. But maybe it helps to understand my "problem"
Thanks a lot in advance!
Regards
Max
- small aperture number: Faster shutter speed and shallow depth of field. Soft images, depending on the lens.
- big aperture number: Wide dof. Potentially less sharp images due to diffraction.
- in between: Usually the sharpest images. Somewhat shallow or not dof.
- How would you/do you choose your aperture?
- Do you almost never use your lens wide open because you (probably) don't get the sharpest image? If so: did you just test what's the sharpest image?
- If you use a prime lens like the 50mm f/1.4 which aperture do you use to get a narrow dof? Since there's a kinda wide range of apertures which lead to a narrow dof (1.4, 1.8, 2, 2.2, 2.8,...).
- Or do you "know" which aperture is best for the current situation?
- Do you make a lot of pictures and compare later?
- What if you have to be quick? If I want to take a foto of two persons and I want both to be in focus but still separated from the background, which aperture should I use?
- If I don't really need a narrow dof (like when the object doesn't have depth, like a wall), which aperture should I use?
- If I want a wide dof, which aperture should I use?
Regards
Max
