- Joined
- Mar 8, 2011
- Messages
- 25,393
- Reaction score
- 9,148
- Location
- Iowa
- Can others edit my Photos
- Photos NOT OK to edit
My default first option will be the sharpest aperture the lens will give me (at a given focal length if it's a zoom).........
My (many many) questions now are:
- How would you/do you choose your aperture?
I test every lens I buy myself, and determine how each aperture performs. Knowing THE aperture the lens will perform best is a starting point. As I know the sharpness characteristics of the various aperture settings of each lens I own, I know which which setting to start out with for best results, which settings will give me acceptable results, which settings will give me so-so results, and which, if any, settings to totally avoid.•Do you almost never use your lens wide open because you (probably) don't get the sharpest image? If so: did you just test what's the sharpest image?
Depends on the situation. If I'm shooting a static subject, I can afford to take my time. But if I want a shallow DOF and the subject is moving rapidly (sports, for instance), I may choose to close the aperture a stop or too to maintain focus. This may bring the background closer to being in focus, but that's a fair trade to make sure the subject isn't blurry.
- If you use a prime lens like the 50mm f/1.4 which aperture do you use to get a narrow dof? Since there's a kinda wide range of apertures which lead to a narrow dof (1.4, 1.8, 2, 2.2, 2.8,...).
Pretty much.
- Or do you "know" which aperture is best for the current situation?
No. Not for DOF, at least. I may bracket for exposure or focus, but not for DOF.
- Do you make a lot of pictures and compare later?
Too many unknowns here to answer. 50mm? 28mm? 200mm? How far am I from the closer subject, and how far away is the other? And how far to the background?
- What if you have to be quick? If I want to take a foto of two persons and I want both to be in focus but still separated from the background, which aperture should I use?
The known 'sweet spot' aperture.
- If I don't really need a narrow dof (like when the object doesn't have depth, like a wall), which aperture should I use?
- If I want a wide dof, which aperture should I use?
What is 'wide' dof?
