Cool product
dylanstraub
Delaware
I was in the local camera joint the other day looking for a 52mm ND filter (2 stops) and the guy showed me this cool Promaster filter that changes from light grey to very dark in the same way you would rotate a circular polarizer. This is a really cool product and I'm just itching to try it out. If it's as good as I think it will be I might opt for the 58mm too. Anyway I just thought I'd share.
Is that the one that goes up to 10? and was it expensive?
circular variable nd filter. they are pretty awesome, and usually pretty pricey...seen some as high as 300 bucks for one.
Yeah I'm pretty sure it does go up to 10 and then resets back to one. It's just pure awesomeness and I only paid $43 for it. It didn't break the bank because it's a promaster and not a hoya. I'm not sure if there really is a difference between the two brands (other than marketing budget lol) so I'll happily use the Promaster.
I'd recommend just getting the 58mm with a step down ring to 52mm. No reason to have two of the same filter when a step-down ring will do the job.
I once looked at the variable ND filter. And noticed that it may have issue with wide angle focal length which is what I really want to use that for (Landscape with water smoothing type scenario), then I decided not to bother anymore.
The issue with variable filter for wide angle lens is the irregularities. I really do not want uneven exposure on my photos. (Even the one that cost over $300 has issue like that, so I assume anything below that should have it)
Of course, if it is used for shooting wide aperture with my 85mm lens in a sunny day, it may not have any issue.
There's a reason that your Promaster cost $43 and the equivalent product from Singh-Ray costs ~$400 and it's NOT marketing budgets. Remember that in even the cheapest lens, tens or hundreds of thousands of dollars of R&D have been used. Does it really make sense to handicap that with a cheap filter? Tiffen and Hoya are not at the top of the pack in filters, but some of their multi-coated lines are decent. If you can, I would suggest returning this and saving for something a little better. It will pay off in the long run!
