Agree; the castle really gets lost in amongst the rest of the detail. The second photo has the best crop/composition, but the worst lighting. Unfortunately, I suspect that this may be one of those images that you just aren't able to capture the way you see it in your mind, and agree to that your sensor is VERY dirty.
I applaud the original designers of this castle for building it in such a way as to blend into the surrounding.
Dust on the lens will look like smaller specs than dust on the sensor which will be larger in the photo and gray. Also, if you clean your lens and retake the photo, you will notice if the spots are missing or not.
Actually, that's not what castles were designed to do at all! They're meant to stand out and scare the **** out of invaders and would-be rebels! I suspect it was built on that rock to make it near-impossible to besiege and it may have lost some height over the centuries.
What castle is that OP?
