- Joined
- Oct 18, 2011
- Messages
- 6,111
- Reaction score
- 2,486
- Location
- Glasgow, Scotland
- Can others edit my Photos
- Photos OK to edit
Yep, boy and dog were shot on a different background, the uneaven dof in the foreground gives it away. That is some custom PS work. Looking at her images she knows how to hide the blend well between to different images.
There's a few shots like the little kid on the pier that are cute but no way that shot is real. Not every shot in her portfolio is PSed though, I think there are a few with clever use of delibetatley angled DOF.
Question is does that make these imagesit's a bit seem like its a bit of a cheat?
Not necessarily... you'd have to go read their tutorials on how to interpret analysis. I ran my own image (the candle on the rug -- which I deliberately didn't touch with anything just to see what would happen.)
It turns out the different brightnesses of the pixels simply mean the JPEG compression has changed. This will NORMALLY happen on areas with sharper edges. When I run the candle through the analysis (it's a pain to do it with an image posted to this site... I did it yesterday by uploading to Flickr, running the analysis against that site, then deleting it (it's not like I want this test-shot in my stream). If someone wants to run it through, have at it (it's just a test shot).
What I saw was that each of the "holes" in the candle had a bit of a highlight around each edge. The potpourri around the base of the candle also shoed up brightly (lots of sharp edges down there). Also... a line extended all the way across the scene in the area where the rug comes into sharp focus.
I suspect the dog and boy probably had sharpening applied. You could always test this with any of your images... just upload an untouched image, upload it and do an analysis, then apply sharpening to an area and repeat. I suspect you'll see the sharpened area shows up brightly.
I wasn't talking about the anyalysis mate, just looking at the DOF in her Flickr image and the way it wraps round the boy and the dog instead of being a straight line like in your example. Now that I've looked at it again the blending between the two different layers in the foreground is really obvious and it stands out quite a bit.
