DIY tripod harness. (Lots of photos)
FITBMX
Burns, KS, USA
I bought a Bogen 3211 tripod a few weeks ago, I love it! When I took it out for the first time for a hike and some wildlife shooting, I found it was a pain to carry with my camera bag. Going through brush and over fences was really hard! So I started thinking of a good way to carry it on my back, but I wanted to be able to get it off quickly. So I started to think of a Biathlon harness, they are easy on, easy off, and cost like $350!!!:aiwebs_016: So I made my own, using plumbing parts from the locale hardware store!:biggrin-93:
I started with four 1/2" brass couplers, and a old 1 1/2" chrome plated brass drain pipe. I used a wire wheel on a bench grinder to take a the drain pipe down to raw brass. Then clamped the couplers to the drain, and soldered them on one at a time.
I cut a slit down one side, for the clamp.
I then cut two pieces of CPVC pipe 32" (more or less) each.
I ran a small rope into one pipe and then through the other, and then tied the rope lower on the leg bowing the pipe. I used a large hose clamp, to clamp the fittings to the tripod leg. And then the test fit! :1219:
I also used a lot duct tape on the inside edge of the CPVC pipe to keep it from cutting the rope.
It seemed to work very nicely, so it was time for padding! I had some used padding from something else, so I cut it into 1 1/4" strips and super glued it down in layers.
Then the covering. I happened to have a bag of leather scraps, so it got suede leather on the under side.
I used super glue to put the leather on.
To finish it off, I used very nice looking lamb skin on the top. Using more super glue! :allteeth:
It's not the best leather job, but it is good enough for me! :)
I really like how it turned out! It stays on, even jumping up and down, or swinging side to side. It's rather comfy, and I can have it off and set up with my camera on it in less than 45 seconds, and cost me 6 Bucks to build!!!:clap:
If anyone wants more details let me know! :)
Ain't never been a problem that couldn't be solved with duct tape and superglue :biggrin-93::biggrin-93::biggrin-93:
I use Gorilla band duct tape and superglue, they are the best!!!
Quit your day job and start building us all one!
LOL, I thought about that, if I did start making them, I would use something different that the CPVC, I would use something more durable. :)
Thanks! :)
Very cool - I would never have thought of that.
I figured if the design is good enough for Olympians, a cheap crummy copy is good enough for me! :laughing:
Thanks!
Well I took it out for it's first hike, and it did great! I went through really tall grass and weeds, climbed over downed trees, over steel gates, and ran with it on. It never got tiring, and nothing broke!!!:bouncingsmileys:
I thought I'd get to see a spider robot at the end.. Disappointed! :lol: :lol:
Way to go man, you're a true engineer! :)
you should put a sports camera next time you go out hiking with that so we can all see everything you go through.
and you could start hunting Sasquaches !!
You should get a monkey (or an assistant but the monkey has no photo rights ;)) to get some photos of you wearing it and putting it on/off ^^
