Do settings need to be adjusted when using an adapted lens?
hooray4mo
I have a Nikon F2, with only 1 lens. I have quite a few Minolta lenses, so I bought an adapter so I can use the Minolta lenses on my Nikon. My question is, is there anything I need to take into account when using an adapted lens? Or can I just shoot as normal? Do settings need to be adjusted at all, or?
The best way to find out is likely to go out and test the setup to see your results, and go from there to decide if you need to make adjustments to your settings. That said, a quick google search reveals that if it's a quality adapter with no glass elements in it, and if you aren't adapting a crop sensor specific lens to a full frame camera, there shouldn't be any reduction in quality or change in perspective.
Some lenses do have some ‘flare’ others are very centre sharp. I would certainly do some test shots and pay attention to the metering.. Check the close and infinity focus.
From what I have read, the minolta md and nikon f mounts have a different flange distance from the film/sensor plain. The minolta has a 43.5-43.7mm flange distance and the nikon f has a 46.5 flange distance. To correct this a lens element has to be added to the adapter as without one the lense will not focus on infinity. As others have written, you'll need to do some trial and error to see what settings need to be adjusted.
Below is a search that explains this.
No, except if you camera needs lens info entered. On my Z8 I enter non cpu lens data. But that doesn't even need to be correct. As I have forgotten to enter a different lens. And it worked absolutely fine. And that included a MD 50 f/1,7 using a dumb (zero eletronic) adapter.
If you're referring to shutter speed, ISO and aperture... normally not. The only exception would be if the adapter has glass in it. Glass is used to 'refocus' the image at a distance not native to the lens. Meaning: the lens won't focus properly on the image sensor/film without it. If the lens is 'pushed' too far forward to achieve focus, then there will be a slightly smaller aperture as a result. Likely not enough to be concerned with, but within the realm of possibility.
Large format film users are familiar with this. Many others are aware of this through variable-aperture lenses (ie f/2.8-4 or f/5.6-1, depending on the zoom setting), but have never made the connection between zooming and physically moving the aperture further from the camera body.
Adapters vary, one of mine gives AF to lenses that don't normally auto focus (some prefocus might be needed with longer focal lengths) most of my adapters are fully dumb, such that the camera has not communication with the lens. With these I must adjust the aperture & focus on the lens.
I believe some adapters allow the camera to adjust the lenses aperture &/or pass through AF instructions but very few of mine do.
Cameras also vary, most of my cameras are happy to meter & set an appropriate shutter speed without any coms, but my Nikon J2 refuses unless it has a chipped adapter. Some also want coms to enable focus peaking - which seems very odd to me.
Cameras with IBIS need the right focal length entered to provide good stabilisation, slight errors are not much of an issue but use a 50mm lens with stabilisation set to 500mm & it's worse than having it turned off
The F2 is a full manual only body. No auto focus or exposure.
The only settings you “may” need to look at is just not using the widest f-stop to compensate for the focal issue of the adapter.
I should have read the OPs message more carefully.
The F2 has a flange distance 2mm longer than minolta's A mount & the SR mount is even worse (by nearly another mm). I don't think additional optics can realistically cope with this much difference, so any adapter will be macro only for any but the very longest focal lengths.
Nikon F mount is the least adaptable of common SLR mounts, about the only lenses that can be adapted to F mount are from the contax N, medium format SLRs and special mounts designed to be adapted like T2, adaptall 2 etc.
Take an exposure reading with your Nikkor. Make note of it. Now do the same with your Minolta lens and adapter.... They ought to be the same.
If you can focus to infinity with the Minolta lens, and your camera meters correctly at different set aperture, I would image odds are your photo will turn out fine.
You'll need to develop the film to find out. I've never tried it. Others have mentioned flange distance variation.... This will be the first hurdle to cross.
Good luck.
The main thing to check is whether the adapter preserves infinity focus and how it handles the aperture. Depending on the adapter, you may need to focus and set the aperture manually.
