Does anyone know why this happens?
ZacFreeland
Michigan
This isn't my full image. I just cropped a little out because this is where it's most noticeable. Take a look please.
Does this happen to anyone else? The pink and green highlights some time stick out so much, I just throw the picture away.
I shoot with a Canon 7d with this lens: HERE and I also use a circular polarizer at all times. I also shoot and edit with RAW. Is this normal or might there be something wrong?
Thanks for looking!
Should also mention that CA varies with zoom level and aperture. Most lenses exhibit worst CA at extremes. Such as the Nikkor AF 80-200 f/2.8D has very bad CA at 200mm f/2.8 but is perfectly acceptable at 80mm f/2.8 or 200mm f/4
Also worth mentioning that certain lenses (read expensive) correct for CA to the point where it's barely noticeable.
In any event, CA is a predictable physical phenomenon and there are various tools for Photoshop, GIMP, etc that will allow you to remove it pretty decently.
