thinkricky
- Joined
- May 28, 2008
- Messages
- 518
- Reaction score
- 25
- Location
- Texas
- Can others edit my Photos
- Photos OK to edit
Is it worth buying the SD performance cards?
Actually, the limiting factor is usually the camera's buffer write speed itself, not the card speed. Your user's manual will tell you what minimum grade cards your camera needs, which is based on the cameras buffer write speed.It only affects the buffer of your camera. If you take 10 photos in quick succession, a slow card will take longer to write the data and therefore will delay your shooting.
Also; DSLR video requires cards that are at least Class 6. I learned that the hard way.
Flash memory - Wikipedia, the free encyclopedia
NAND flash memory cards are much faster at reading than writing so it is the maximum read speed that is commonly advertised.
As a chip wears out, its erase/program operations slow down considerably,requiring more retries and bad block remapping. Transferring multiple small files, each smaller than the chip-specific block size, could lead to a much lower rate. Access latency also influences performance, but less so than with their hard drive counterpart.
The speed is sometimes quoted in MB/s (megabytes per second), or as a multiple of that of a legacy single speed CD-ROM, such as 60×, 100× or 150×. Here 1× is equivalent to 150 kB/s. For example, a 100× memory card gives 150 kB/s × 100 = 15,000 kB/s = 14.65 MB/s.
Performance also depends on the quality of memory controllers. Even when the only change to manufacturing is die-shrink, the absence of an appropriate controller can result in degraded speeds.
