Dreamfield
Maybe it's just my work monitor, but it seems a little cool. If tireiron says it not, I'm sure it's the monitor.
Yes the original is definitely on the cool side - the subject was obviously in some shadow. Warm it up a bit for sure, but Rick's edit doesn't look right either. Otherwise it's a great shot!
Better?
here's my trick for balancing color when you have a good bit of eye white. Point your color meter at the eye white and adjust until you get close to equal RGB. I found that it needed a pretty decent amount of cooling and a bit of moving towards green in the magenta green slider. I found a spot in the eye white that was about the average of the entire eye white and then moved the sliders until I got: R: 94, G: 94 B: 97
That put her skin at about R: 227 G: 208 B: 211 which is about right.
The above trick will most always get you in the ball park for young people whose eye whites aren't overly red or yellowed.
here is the result:
Not My Photo, showing WB by franklinrabon, on Flickr
I think all 137 thousand members should edit this photograph.
I added a slight vignette to it, and darkened it a bit.
My biggest issue with it is that the background is brighter than the subject. The subject also has GORGEOUS eyes if you look closely enough, multiple colors fading into one another. But they're so dark in the original from no direct light getting in there to fill it, that they look flat brown at first glance.
The background needs to be darkened and desaturated, and the subject needs to be brightened a bit.
Here is what I though as far as an overall edit goes:
Not my photo, showing overall edit by franklinrabon, on Flickr
compare to the WB corrected only version:
I vote for Derrel's edit ;)
Either way she's a gorgeous lady and that's a great shot.
