DSLRKIT 4 Channel Wireless Studio Flash Trigger AC-04
BestOfferBuy
Price: $13.00
  • DSLRKIT AC-04B 4 channels FM (Transmitter + Receiver) Set Wireless Flash Trigger for Studio
  • Extra receivers if you need:
    the transmitter of DSLRKIT brand can trigger all the reciever as long as it is DSLRKIT brand,
  • E.g.
    4 Channel Transmitter can trigger the reciever from DC-01A, AC-01A, DC-02A, AC-02A, DC-04A, AC-04A, PT-04A, DC-16A, AC-16A;eg.
    4 Channel Transmitter can trigger 16 Channel Receiver,but only work on 4 channels from the receiver(you have to find from the 16 Channel of the Receiver to see which 4 channels is work on).
Introduction
  • The brand is called DSLRKIT.
    The remote trigger for studio flashes and outdoor flash is used as the controller of synchronous trigger studio flash of cameras.
  • It consists of a signal sender and a receiver trigger and works by means of the frequency modulation wireless remote control.
  • The signal transmitter adopts the advanced circuit and components, and can transmit the coded FM wireless signal. The circuit of the transmitter has the function of standby and hibernation, thus it has low power consumption; the products can work under the standby mode for more than one year with only one battery; continuously trigger for thirty thousand times. the trigger current is only 0.01MA, which will definitely cause no damage to the flash contact of the camera. The transmitter is applicable to the traditional or digital camera with hot shoe or PC controlling interface.
  • Receiver trigger adopts dry battery for power supply, which is safe, energy-saving, and convenient. The product adopts micro-computer for controlling the decoding, Which has superior anti-interference capability; sensitive reaction speed, the highest synchronous speed can reach 1/500 sec.
  • Transmitter Receiver Power Source: 23A AC 100-230V
  • Outdoor operating distance (open area): >30M
  • Indoor operating distance: >10M
  • Frequency Channel: 4
  • Operating Frequency: 433Mhz
  • Outdoor Synchronous Speed (open area): Max 1/500sec
  • Indoor Synchronous Speed: Max 1/250sec
How to use:
• Make sure the channel selector of both transmitter and receiver at same position
• Insert the receiver's trigger output plug into your flash's jack
• Press the test button on your transmitter. The studio light should now flash
• Insert the transmitter's hot shoe socket into your camera's hot shoe jack
• (if your camera does not have a hot shoe use a PC sync cord and insert into the socket)
• You should now be ready to start shooting
  • Weight: 35 g
Buy DSLRKIT 4 Channel Wireless Studio Flash Trigger AC-04 here
New Products:
25mm f1.4 C mount CCTV Lens for M4/3 EP1 EP2 G1 GF1 GF2 & NEX-3 NEX-5 NEX-7
YongNuo YN-560 Hot Shoe Flash Speedlight Wireless, Light Trigger for Canon and Nikon D-SLR
Meike Battery Grip MK-A550 for VG-B50AM Sony A580, A560, A550, A500
1/4 Inch Tripod screw to Tripod screw Adapter for Flash
]Canon FD Lens to SONY NEX-5 NEX-3 NEX-VG10 NEX Adapter
EyeCup for Canon Eb 5D Mark II 60D 50D 40D 30D 20D
YongNuo YN-460 Flash Speedlite for SONY Alpha, Minolta A390 A290 A550 A500 A450 A380 A330
camera accessories, camera bags, camera lens, digital camera accessories, camera filters
