DX vs. FX for Bird Photography
I'd recommend buying a good tripod, but I'm not a bird shooter unless it's sitting on my hand. Should bird shooters rely on tripods?
Sounds like your just starting out. Your best bet is the D7100 for action type shots in jpeg. You can get away with a cheap combo like a Sigma 18-250 for around $400 and get pretty good results.
Tripods are great for static wildlife shooting. That is when you've set yourself up in a hide or other position and you're going to sit there for a fair while waiting for the shot to come to you. In that situation they provide an ideal means to holding the weight of your setup and also providing a stable shooting support when the shot comes along.
When you're more mobile and walking around they can be a hindrance - yes they are giving you that support, but chances are if you're moving the tripod is going to take a few moments to deploy; plus its adding weight so your arms are going to be even more tired (which means you need it deployed all the more).
Some people drop one leg and use a tripod like a monopod so that it can be used faster; however its honestly easier (if you do this a fair bit) to use a monopod - its quicker to use and a lot lot lighter than a tripod.
Note a lot of the versatility of a tripod comes from the tripod head. That is why good tripods are sold with a removable head (or no head at all). So that you can change the head for different situations for best performance.
not much experience in birding, but i use my canon 7D for action shots, and the buffer is huge. At full raw, its 25+ shots at 8 fps before it slows down to 4fps, and once you're at that point, it's continuous. The Mark II surpasses that and shoots at 10 fps.
But a 7D body refurbed from canon is probably around $700 or $800 right now, so it really depends on your budget.
