Event Photography - Even exposure for foregrounds and backgrounds...Advice?
Buchi
Hi All,
I am a photography enthusiast who has been shooting for over 5 years now. I have shot a couple of events and would like to improve on getting the perfect exposure/lighting for distant backgrounds (10 feet or more) in a reception hall. I majorly shoot in manual mode with bounce flash attached to the hot shoe of my camera for 90% of the time and then expose for the subject. For the majority of my photos I have dark backgrounds especially when the backgrounds are a few feet away which I always correct in post. However in some cases I never manage to recover the shadows fully without affecting the quality of the photos. I've seen some images of some event photographers with excellent exposures for both subject and backgrounds in dimly lit event halls and often wondered how it was achieved. Is there a technique or setting that I can use with my current setup (DSLR + bounce flash on hot shoe) or must I use other flashes in conjunction with the one on the hot shoe? Any thoughts, ideas will be most appreciated. Many thanks.
Are you familiar with the photographic technique commonly known as dragging the shutter? Dragging the shutter means slowing the shutter speed down so that the f-stop in use for the flash also creates a decent exposure for the background ambient lighting conditions. Many times a shutter speed as slow as 1/8 of a second will be needed. Of course by using higher ISO levels, it's possible to get the background to" burn in" better with speeds that are a little bit faster, such as 1/20 second or thereabouts.
Hi Derrel. Many thanks for your quick response. I have never used the dragging the shutter technique but absolutely worth trying. It makes perfect sense as I reckon the flash will do the job of freezing the scene and eliminate blurriness which otherwise would have been introduced by the slower shutter.
Sent from my iPhone using ThePhotoForum.com mobile app
